Go to Post .. if no one gets ahead no one gets left behind. - Koko Ed [more]
Unread 27-09-2011, 12:32
2611.Shooter 2611.Shooter is offline
Programmer
AKA: Andrew Lavery
FRC #2611 (Vectors)
2611.Shooter is infamous around these parts2611.Shooter is infamous around these parts
Re: Programming Build Times?
Using labview, my team's computers often took more than 10 minutes to build, and a similar time period to deploy over a wired connection. (2 years ago, might have changed. but I doubt it) Last year, we used windriver, and build+deploy times were generally around one minute. on the same computer as the previous year, so its not like its a hardware difference. But labview takes all of 30 seconds to learn, so...
Unread 27-09-2011, 15:01
It did change. The FRC distribution of LabVIEW last year saw a significant improvement in build speed. It's still a turtle compared to C++, but it's fast enough that I don't have a problem recommending it.
Developing and debugging using the Run command is a lot faster than building a permanent executable, too. It greatly shortens the typical "edit-compile-download-debug" cycle.
Unread 27-09-2011, 15:12
byteit101's Avatar
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
C++ has a interesting compiler model that saves tons of time on most builds. In a nutshell, it only builds the .cpp files that have changed, so if you have a million lines of code, and change one file, it only needs to recompile the one file (which produces a .o file), then joins all the .o files together, which is much faster than the .o file compilation. The result: a speedy build 90% of the time. Unless you mush lots and lots and lots of code into one file, C++ is fast at compiling changes. Do be aware that the compiler is smart and figures out if dependencies of a file change most of the time, but occasionally the compiler does not recompile something that it should (.h file changes usually), leaving two incompatible .o files. Rebuilding solves this issue (when we have errors, most of the time rebuilding solves it), and our code last year (which had quite a few largeish files) would rebuild completely in about 30 seconds, and a regular build of our main file took 10 seconds tops. C/C++ compiling is an interesting subject.
Watchdog.Kill();
