Go to Post when I was a young whippersnapper, we didn't even HAVE Internet access at my high school in my podunk farmer town of Kinsman, OH! - Travis Hoffman [more]
Unread 27-09-2011, 22:17
Frenchie461's Avatar
Frenchie461 Frenchie461 is offline
iScout
AKA: Brian, Frenchie, or that guy
Team Role: CAD
Frenchie461 is a jewel in the roughFrenchie461 is a jewel in the roughFrenchie461 is a jewel in the roughFrenchie461 is a jewel in the rough
pic: Sorta WCD
Unread 27-09-2011, 22:18
Andrew Lawrence
Posts: n/a
Re: pic: Sorta WCD
Why are you using the motors apart, with 4 separate gearboxes?
Unread 27-09-2011, 22:30
MattC9's Avatar
MattC9 MattC9 is offline
MattC9 has a spectacular aura aboutMattC9 has a spectacular aura aboutMattC9 has a spectacular aura about
Re: pic: Sorta WCD
Hmmm, looks like a 624 drive, they are notorious for using dewalts like this. Let me try and find you a few pics it might help. Also how would the chain run work?
Unread 27-09-2011, 22:39
Jeffy's Avatar
Jeffy Jeffy is offline
Retired, for now
AKA: Jeff Gier
FRC #2410 (Metal Mustang Robotics) #159 (Alpine Robotics)
Jeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant future
Re: pic: Sorta WCD
Sorta WCD is sorta cool.
I kid, wanna give us some details please?
Metal Mustang Robotics 2410 (2008-2011)
2008 STL Rookie All-Star
2010 GKC Finalists
2010 OKC Champions
Alpine Robotics 159 (2012-)
2012 CO Finalists
700 miles from home, 2 miles from FRC. Life is good.
Unread 27-09-2011, 22:49
Re: pic: Sorta WCD
Function of a DeWalt 3-speed--you can really only fit one motor to a gearbox without adding another gearbox on top of it to join the motors. Why would you need the extra speed? Let's see--extra push, easier transition to high gear, and LUDICROUS SPEED!
It wouldn't hurt to add a chain run to make sure that each side gets both motors powering all the wheels together. I realize that those aren't shown, but it may be worth having if weight (and the field) allow.
Unread 28-09-2011, 07:11
Hawiian Cadder's Avatar
AKA: Isaak
FRC #0159 (Alpine Robotics)
Team Role: CAD
Re: pic: Sorta WCD
I am currious as to what ratios are in those dewalts. If i remember correctly it is something like 1-12, 1-16, 1-42. what ratio are you thinking of using for the chain, and what fps does it go?
Unread 28-09-2011, 08:02
Chris is me's Avatar
AKA: Pinecone
Re: pic: Sorta WCD
I believe with CIMs most people remove a stage to make the transmissions run at 1:3 1:4 1:12.
Unread 28-09-2011, 09:00
AKA: Isaak
Team Role: CAD
Re: pic: Sorta WCD
Ahh, that is correct, My experience is with a dewalt and fisher-price pairing.
This also makes a lot of sense because the first stage is held together largely by the plastic casing, while the deeper in stages are much more secure.
Unread 28-09-2011, 15:53
iScout
Team Role: CAD
Re: pic: Sorta WCD
Just to clarify the ratios on the dewalts with the first stage removed are 12:1, 4:1, and 3:1. These are further reduced by a 22:32 sprocket reduction giving speeds of 5, 13, and 17fps (Thank you JVN for your design calculator). The chain is run past 2 idlers to put the sprocket on the drive motor in the right place to only use 1 chain rather than one for each wheel.
"As a general rule, the most successful man in life is the man who has the best information." - Benjamin Disraeli (1804-81)
Unread 28-09-2011, 15:54
iScout
Team Role: CAD
Re: pic: Sorta WCD
I'll try that, but that doesn't work quite as well with performance wheels, so I'll probably change those to plactions in the center 2.
Unread 28-09-2011, 18:47
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
Re: pic: Sorta WCD
Wait, one chain per side or one chain per motor and the 2 closest wheels? While the latter sounds fine, I would not advise the former due to the fact that a single failure would render the robot un-steerable. If two chains are used per side, on the other hand, there is at least some degree of redundancy.
Unread 28-09-2011, 21:08
iScout
Team Role: CAD
Re: pic: Sorta WCD
1 chain per dewalt, which makes it 2 per side
