Go to Post before you post, ask yourself: Is there a good reason to post this? - Jeff Waegelin [more]
  #36   Spotlight this post!
Unread 29-09-2011, 11:18
gblake's Avatar
gblake gblake is offline
6th Gear Developer; Mentor
AKA: Blake Ross
no team (6th Gear)
Re: Match Scheduling Algorithm Competition
I certainly wouldn't argue against adding "Titan Matches" to any of the feature lits I have put in other scheduling posts/threads (for the moment I'm being too lazy to go find and copy all of them into this discussion).
One big reason for saying that, is my belief that Jesse's excellent suggestion for developing an open source scheduler is best implemented by developing a "scheduler", not a the-way-we-always-run-FRC-matches scheduler, or a VRC scheduler, or an FLL scheduler, or a league-play scheduler, or an FiM scheduler, or etc.
If the team that implements an open source scheduler is mostly drawn from Chief Delphi participants, they will sometimes have to force themselve to lift their heads up out of the STEM robotics weeds (FIRST and VRC in particular) and look at the project as a scheduling project, not a FIRST (or BotBall, or VRC or ...) task.
The result should be something useful for the STEM Robotics world, and for other uses.
Blake
