Go to Post There are a maximum of 80 balls in play . If all the balls are in the goals or out of play and the human players won't throw them back in, I guess the robots might try line dancing or doing the cha-cha. - Rick TYler [more]
Go Back   Chief Delphi > Competition > OCCRA
Unread 30-09-2011, 20:17
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
[OCCRA]: Specs for OCCRA Globe motor
Does anyone have the specs for the Globe motor that is OCCRA legal?
I have specs from the FRC globe motor, but the ones I have with our OCCRA stuff dosen't look like the FRC one (well, it looks roughly like the FRC one, but it has a plate on the top which is square and integral to the transmission housing, which the FRC one lacks, and appears to be of a slightly different size)
Kettering Motorsports
Unread 03-10-2011, 10:05
Mike Martus's Avatar Unsung FIRST Hero
Mike Martus Mike Martus is offline
FRC #0051 (Wings of Fire)
Mike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond repute
Re: [OCCRA]: Specs for OCCRA Globe motor
I will look however, over the years I am sure it is gone.
Best spec is.... attach power and observe.
Mike Martus
Unread 03-10-2011, 21:12
apalrd's Avatar
More Torque!
VRC #3333
I talked to Jim Zondag today, he suggests to assume it is roughly the same as the FRC one and use the FRC spec. For the application the motor is under, with the FRC spec, I am running nowhere near a bad point in the power curve, so if it's a little off, it *should* still be fine. The greatest part is that it's only a sprocket change if I'm wrong, and the mechanism is very low torque.
For reference, the FRC spec is (from the FRC2009 motor data):
16.95 n-M torque stall
21.58 amp current draw stall
81 rpm free speed
0.82 amp current draw free
55 w peak power (10.5v)
