Go to Post Quitting FIRST was so hard that I felt like I needed a 12 steps program to help me through it. - Ken Leung [more]
Go Back   Chief Delphi > Other > FIRST Lego League
Unread 01-10-2011, 18:56
BJC's Avatar
BJC BJC is offline
Simplicity is Complicated!
AKA: Bryan Culver
FRC #0033 (The Killer Bees)
BJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond repute
Re: Robot Chassis
Originally Posted by Qbranch View Post
Hello FLL community,
I have a community discussion point, which I'm interested in hearing other teams' opinions about.
Does your team design their own robot chassis each year? Or re-use and tweak the same one every year? Or, does your team use an already designed chassis found online or elsewhere?
The year and the past our team is using a chassis design we found online to start with, to focus on attachments, programming, and any minor modifications we might need to make to the chassis.
What do you do, what are your opinions FLL community?
Thanks,
-q
I use to be in FLL and now help out a team in my area so I have some experience. I have always built a new drivetrain -- it's part of the process. This shouldn't be a big deal because legos are so easy to take apart and put togeather; you can try multible configurations in under an hour. This allows you to place the third motor where you need it, make your robot skinny or wide, etc to best fit the game challenge.
If you do build an origional drivetrain I suggest trying smaller wheels and supporting the axel on both sides of the wheel. That'll will give you a very reliable configuration.
Regards, Bryan
robot robot robot? Robot. Robot? Robot!
-----------------Team 33------------------
Unread 01-10-2011, 23:18
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
FRC #1024 (Kil-A-Bytes)
Qbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond repute
Re: Robot Chassis
Regards, Bryan
Thanks for the thoughts, Bryan. And I'm totally using your signature quote for something.
-q
Electrical Engineer Illini
1024 | Programmer '06, '07, '08 | Driver '08
