Re: Java SDK Question
No, as you have discovered, the cRIO runs the Squawk JVM, which implements J2ME (as well as a small subset of J2SE). Reflectance is among the features that is not supported.
Note that although no java.util.Map is supplied, there is an implementation of java.util.Hashtable that will do the trick for you. |
