Go to Post Yippee! Someone else that can have their every word over-analyzed, mis-read, inverted, converted, perverted, misinterpreted, reverted, and garbled besides just me! - dlavery [more]
Unread 23-09-2011, 10:39
Adam.garcia Adam.garcia is offline
Design Mentor
FRC #0004 (Team 4 Element)
Adam.garcia is just really niceAdam.garcia is just really niceAdam.garcia is just really niceAdam.garcia is just really nice
Re: Current Draw vs. Stall current
Originally Posted by Brandon Holley View Post
Using one here is fine, but just make sure you are not also accounting for extra margin somewhere else and compounding your margin.
-Brando
Thanks, I will keep that in mind.
Unread 03-10-2011, 13:44
kws4000's Avatar
kws4000 kws4000 is offline
Team Mentor - Programming
AKA: Krazy Karl
FRC #2405 (Divided by Zero)
kws4000 is a jewel in the roughkws4000 is a jewel in the roughkws4000 is a jewel in the roughkws4000 is a jewel in the rough
[quote=Jared341;1077997]There are a few ways to defeat defense...
Pushing (works great against most, but just as with speed, you will eventually encounter a bot that can push you to a standstill)
In 2009 (remember the slick surface?) our lead rogrammer added in code to increase the allowable pushing power of our bot. We weighed 85 lbs on the chart, and we were pushing around 120 lb bots with those ungainly trailers.
//Traction control calculations
if(m_rightStick->GetRawButton(1) == 0) {
if (ncount1 == 0 && ncount2 == 0) {
ncount1 = count1;
ncount2 = count2;
} else {
speed_error1 = ncount1 - count1;
speed_error2 = ncount2 - count2;
ncount1 = count1;
ncount2 = count2;
//ajjy = ajjy * .95;
if (speed_error1 > 30 && speed_error2 > 30 ) {
float ajjy = ajjy * .9;
float ajx = ajx * .9;
printf("Motor Y: %f", ajjy);
printf("Motor X: %f", ajx);
It worked, and it might help with mechano wheels, but I don't think this code will really be usefull for at least another 5 years...
Ready for kickoff?
Mentoring:
1) Educating students on the ability to learn and have fun at the same time.
2) Giving back to those who made you who you are.
2009-2011 Student 2405 Electrical/Programming & Asst. Captain
2012-???? Mentor 2405 Programming/Jack-of-all-Trades
Unread 03-10-2011, 14:31
the man's Avatar
the man the man is offline
AKA: Jacob Overla
FRC #4004
the man is on a distinguished road
Now ask your self how long will a 17 amp hour battery last while four motors draw 110 ish amps? How long untill your wire melts? I feel there is some thing wrong with your calculations.
Every day is a new adventure!!!
Unread 03-10-2011, 23:09
Design Mentor
The 121 Amps only occur when at max continuous load (ie. We are pushing against a wall, or an immovable robot). There is no feasible reason for pushing against an immovable object for more than a few seconds.
To get around ever having to go near this 121 Amps, our programmer is working on some code which will sense if the Amps rise too high while in high gear. If the robot senses high Amps, it will automatically shift to low gear in order to prevent possible breaking.
We just saw this a few days ago while looking at 399's drive code. Ingenuity to the max!
Unread 07-10-2011, 22:17
Adam,
To add to your discussion, a motor draws stall current whenever the motor is not moving. That is why there is a current spike when you first apply power to the motor. The current is proportional to the applied throttle value. If you are at full throttle and using fully charged battery and low resistance wiring, you can expect near the rated stall current when starting.
