Go to Post 1. Build a robot. 2. Don’t let it get destroyed. - B-Bot [more]
Unread 01-10-2011, 20:10
whiteice22 whiteice22 is offline
FTC #4981
whiteice22 is an unknown quantity at this point
[FTC]: How many balls can fit in the off-field goal?
I heard on another thread that you can fit 4-6 balls, but i looked at the complete build guide and it looks like you can only fit one at a time.
Unread 01-10-2011, 21:50
wilsonmw04's Avatar
Coach
FRC #1086 (Blue Cheese)
Re: [FTC]: How many balls can fit in the off-field goal?
if you are VERY careful I saw 9 today at our FTC workshop at VCU this morning. The more reasonable number is 4-5.
Unread 02-10-2011, 13:27
SousVide SousVide is offline
SousVide is a splendid one to beholdSousVide is a splendid one to beholdSousVide is a splendid one to beholdSousVide is a splendid one to beholdSousVide is a splendid one to beholdSousVide is a splendid one to beholdSousVide is a splendid one to behold
Having trouble with this one.
Ball is 2.25" diameter and PVC pipe is 2" diameter. The sensor is sitting inside of the 2" PVC pipe. So it looks like anything more than one ball in the off-field goal is stacking balls inside of the 4" coupler from reading rule 2.4.2.4...
Unread 02-10-2011, 14:36
kz2zx kz2zx is offline
Ruthlessly Insufficient
FTC #5246
kz2zx will become famous soon enough
http://www.usfirst.org/sites/default...CTIONSEPT6.pdf
There is a (1x1-1/2") wooden post inside the goal 13-5/8" tall. The overall height of the goal is 17".
I'd say the cost of the goal is low enough to buy the parts and try it empirically (or you can stand in the aisle at Home Depot with racquetballs).
Unread 04-10-2011, 18:21
FTC #4981
Well is that 4-5 within the actual goal or is that stacking outside?
Unread 05-10-2011, 13:03
SteveGarward's Avatar
SteveGarward SteveGarward is offline
Red 5, standing by...
AKA: 7 years already
FRC #0111 (WildStang), FRC #3132 (Thunder Down Under)
SteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud of
These are a couple of photos I took at the Illinois FTC kickoff of the off-field goal with a ball in it (here and here)
While people were able to place another 2-3, or even 4, balls on top by hand, you would need a well-designed mechanism for placing more balls in the off-field goal to have them stay in/on the goal.
FRC Team 111 - WildStang (Mentor, Drive Coach)
FTC Team 7458 - Full Force! (Mentor, Coach)
FRC Team 3132 - Australia's FIRST FRC Team! (Holy crazy first year, Batman!)
Unread 09-10-2011, 16:53
Mistercheif Mistercheif is offline
AKA: Alec
FTC #0712 (Phoenix Robo Works)
Mistercheif is an unknown quantity at this point
We've built the field, and you can fit in 3-4 balls relatively easily without risking them falling out. Five is possible, but it is unlikely that it won't just bounce out.
