Go to Post FIRST has given me too much for me to leave without leaving a mark... - Joe G. [more]
Go Back   Chief Delphi > Technical > CAD > SolidWorks
Unread 04-10-2011, 19:39
Littlemarks2 Littlemarks2 is offline
FRC #2016
Littlemarks2 is an unknown quantity at this point
How do you make gears on solidworks
I need to make gears for a project and i'm having trouble
Unread 04-10-2011, 20:13
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
Re: How do you make gears on solidworks
SDP-SI has CAD models of pretty much any common gear size you could need.
If you need an odd-sized gear (such as something with a non-commonly available number of gear teeth), get a copy of Machinery's Handbook and look at their section on gear tooth profiles. A few years ago I used this to draw up an approximately correct (I simplified the tooth profile to improve SW performance), equation-driven gear tooth SolidWorks model. Using equations, I set the number of teeth, diametrical pitch, pressure angle, face width, and bore options and it automagically generates the gear model.
Art Dutra IV
世上无难事,只怕有心人.
Unread 28-10-2011, 20:53
mplanchard mplanchard is offline
Marie Planchard, SolidWorks
mplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond repute
Before you model a gear, go to www.3DContentCentral.com. I used to use Boston Gear when I was a designer, but there are many manufacturers. You need to specify parameters such a pitch, diameter, number of teeth.
You will get a simplified version of the gear, with our without a keyway.
Although this does not contain the exact curve, they are close enough for a purchased part. When given the chance - get the model from a supplier, don't waste time creating the model. Marie
