Go to Post A quote from the Southern California Regional Visitors guide: "If you are having problems the FIRST thing to do is ask your neighbor for help" - ChrisH [more]
Unread 14-09-2011, 22:05
James Critchley James Critchley is offline
James Critchley is an unknown quantity at this point
Team 302's Off-Season Robotics Programming Competition
Team 302 is introducing a new kind of off-season competition... A virtual one.
This FIRST year's challenge (in what we hope will become an annual event) is "Robust Autonomous".
For complete details visit the VIRSYS webpage http://www.virsys.org/contest.html.
This contest specifically targets LabVIEW programmers and emphasizes control. However, the aim is to increase scope beyond labVIEW and programming in future years to include design elements and so on.
Good Luck and have fun!!!
Unread 22-09-2011, 15:30
JohnGilb JohnGilb is offline
Programming Mentor, Drive Mentor
FRC #0488
JohnGilb has a spectacular aura aboutJohnGilb has a spectacular aura aboutJohnGilb has a spectacular aura about
Re: Team 302's Off-Season Robotics Programming Competition
This is incredible!
I have a few students who would probably have a ton of fun in this competition.
Also, maybe you can help clear something up - is there any way to get "true" robot position/orientation information from VIRSYS.exe? I'd like to be able to compare where the robot thinks it is against its precise field position.
Unread 22-09-2011, 19:58
John,
The values you are looking for are sent to the Image Generator (IG) in exactly the same way messages are sent and received in the LabVIEW code.
If you want to peek at them you can setup another IG in the VIRSYS config (text) files (physics.txt?). Set the number of IGs from 1 to 2 and duplicate the IG definition using different ports... Make the last digit "4" as I believe 1,2,and 3 are already in use). The information you're looking for will go out on/to this port.
Then all you need to do is setup a listener in LabVIEW exactly the same way the sensors are read (but you must match the port you sent the extra IG message out to). This message SHOULD be <timestamp, x, y, z, heading, pitch, roll, arm angle, wrist angle, clamp on/off> where x,y,z are in inches, x is down the field, y to the left and z up. heading pitch and roll are in radians and appear in that order and right handed about "body fixed" axes. Note that this signal is 11 floats (singles) long, so you also need to update the receive array size.
This is a good feature to have but you really don't NEED it. If you implement it please send your project file and config file to the VIRSYS e-mail address and I'll get it onto the website. It's a great request so if you really want us to do it, just let us know. Give us a few days to coordinate who will do it then get it done.
There are still LOTS of questions to answer, so keep them coming!
Unread 27-09-2011, 18:06
FRC #0488
I'm afraid you've sort of lost me - without really knowing your architecture, the concept of an Image Generator is not easy to understand (or how it relates to other components). Do you have a diagram of the overall project?
Do I have these concepts right:
--I need to configure VIRSYS.exe (via an existing text file) to send data out on another channel/port
--I need to configure the LabVIEW program to read data on that channel/port
--I need to add code to the LabVIEW program in order to parse that data
Is this right?
Unread 28-09-2011, 00:24
Your interpretation is correct.
My apologies, the discussion was intended to be an extension of the "getting started" documentation (to use the term "documentation" loosely) on VIRSYS.org. The prior version of the getting started page mentioned the configuration files... I just noticed it no longer does, so that would be a problem.
The top level architecture is simple, and being clear about what it is should go a long way.
A VIRSYS simulation is three components. Your software, the physics model, and the 3D visualization (image generator, IG).
These three components run independently and send and receive UDP (networking) packets between each other. Your software environment (LabVIEW) and the physics model send to and receive data from each other. The IG never sends data and only listens to (receives data from) the physics model. The IG can be absent and apart from no visuals, the simulation should run.
For convenience, the physics model and IG are packaged in a single multi-threaded executable (VIRSYS.EXE). However, the network type communication between them is still there. You can configure the executable using the various (commented) text files which VIRSYS.EXE comes with (unzipped in the same directory). For example, you can tell the executable not to run physics which is useful for various things including constructing multiple remote views of the same simulation (on remote computers).
The comments are not fabulous, so here's what you need to do to the file "virsysPhysics.txt" so that it sends out an additional IG message:
before:
VIRSYS (VIrtual Robot SYStem) - Physics model configuration file
50001			<- local receive port
127.0.0.1		<- LabView host
50002			<- LabView host port
1			<- Number of image generators
127.0.0.1		<- IG host (1)
50003			<- IG host port (1) ...  additional hosts repeat like this
robot.txt		<- robot config file
0.001			<- integration time step
0.01			<- I/O time step (data publication frequency)
after:
2			<- Number of image generators.  NOW 2!
127.0.0.1		<- IG host (2)  ACTUALLY WE'RE SENDING THIS TO LABVIEW FOR DISPLAY
50004			<- IG host port (2)
Note that you can run LabVIEW on a different machine if you wish by changing the "LabView host" from the loopback localhost IP address 127.0.0.1 to an actual remote IP address. Of course LabVIEW then needs to know where to send it's data.
Of your original 3 steps, the first is taken care of.
Yes, done.
I would replace "configure the" with "write/modify the" Thankfully there is an example of exactly what you need to do already inside the LabVIEW Trainer. You just need to find it, copy and paste, and change a few parameters. It's pretty easy to find inside the "HW" block on the Main VI. You want to mimic the Sensor Read/Recv procedure with only minor changes. I recommend performing all of your activities inside a newly created block on the Main VI directly below the HW block. This will give it it's own execution thread. Don't forget to use 50004 as the port number for this and adjust the size of the array to accommodate the size of the new message (per my last post).
Yes. Parsing is also shown in the Sensor Recv procedure. Your signals are still "singles" (floats)... All you need to do is index into the array and verify which is which.
Adding a front panel for display of this data would be a nice touch.
Unread 01-10-2011, 23:13
Looking at the labview project, it didn't see anything that looked like autonomous independent. I don't think it would be very hard to add, but didn't want to reinvent the wheel if it was already there. For periodic tasks, it looks like additional loops could be added to HW_Interface, or to minimize messing with the framework, another vi could be added in parallel.
Unread 02-10-2011, 13:29
Joe,
The Autonomous / Tele-op / disable, etc. mode switch is located on the surrogate Driver Station VI (DSInterface?... sorry I wanted to reply, but I don't have it open). It is a pulldown menu above the arm controls dials and switch. Ideally the robot code determines what to do based on that signal and all of the high level stuff happens in the Robot Control VI.
You are correct and do need to add your own stuff to the HW interface. Ideally that is just PID, etc. controllers and doesn't look at the Auton / tele-op state at all. However, if you have different low level controls (tele-op vs. auton) then you would need to. Alternatively, if you were to have scripted maneuvers within teleop, then the signal would be something set by both auton and teleop independently. So you can argue that you never need to look at that mode signal in there.
It's been a few weeks now... I'm curious to know how many students are out there working on this.
Keep the questions coming!
Unread 03-10-2011, 10:59
krudeboy51's Avatar
krudeboy51 krudeboy51 is offline
Only Programmer
AKA: kory
FRC #0369 (369)
krudeboy51 is a glorious beacon of lightkrudeboy51 is a glorious beacon of lightkrudeboy51 is a glorious beacon of lightkrudeboy51 is a glorious beacon of lightkrudeboy51 is a glorious beacon of light
Send a message via AIM to krudeboy51
COOL!, one question though, what software did you use to create the field in the picture?
Unread 03-10-2011, 17:06
The software in the pictures is constructed in C using GLUT. Googling "GLUT opengl" will get you tons of links.
Alternatively we have a Unity 3D version of the visuals which was impemented by one of our seniors last year. Develpment stopped after the championship and it's not quite ready for prime time. Unity offers the potential to directly import robot geometries and get outstanding visuals with less effort.
Since we are interested in deploying the simulation to a single computer, the GLUT visualization is preferred because the computational resources consumed are very small. That said, we are observing issues on some windows platforms where the "sleep" function is not properly yeilding control to other processes.
Unread 06-10-2011, 00:27
I've attached my changes to labview trainer project to make it more like the LabVIEW robot framework. It adds separate VIs for Teleop, Disabled, Autonomous Independent, Autonomous Iterative, and Periodic Tasks. This makes it easier to move code from our 2011 robot to the trainer.
Unread 09-10-2011, 23:27
In Read_sensors, there appears to be an issue with the right distance sensor. It's source is "VIRSYS right_speed", and I think it should be "VIRSYS right_angle".
Unread 10-10-2011, 02:41
Joe,
At the moment I have no way of looking at the code or posting an update until the weekend. It sounds like a cut and paste error on my part. Can you verify the correction and post speciffic steps for the correction identifying the exact VI (or VIs) where changes must be applied?
Thanks!
Unread 10-10-2011, 15:57
One of our other mentors/recent grads got a description for the exact fix.
I had a few minutes so I looked into the VIRSYS right distance sensor issue.
Under
VIRSYS_Main.vi -> HW_Interface.vi -> Read_Sensors.vi
The calculation for the R_DIST_SNSR draws from the Global Variable VIRSYS_R_SPD instead of the Global Variable VIRSYS_R_ANGLE, this should be a simple fix.
Left click on the VIRSYS_R_SPD that is being replaced, and from the drop down menu that appears select the VIRSYS_R_ANGLE.
Good work!
Unread 10-10-2011, 22:47
Yes, that's what I did. I found it by looking at the code, I haven't tried reading sensor values, yet. Theoretically, there could be an offsetting error somewhere.
Unread 12-10-2011, 23:49
I scored 3 tubes on the top row in 17 seconds, without moving the shoulder, and I think it would be easy to get it under 15 seconds.
On my quad core i5, virsys.exe takes approximately 50% of my cpu, and on my dual core laptop, it takes over 90%. Is that expected?
