Go to Post Messy wires are a pain in the chassis - [more]
Unread 05-10-2011, 14:42
Dr Theta's Avatar
Dr Theta Dr Theta is offline
Lead Mentor
AKA: Derek Messer
FRC #2232 (Deus Ex Machina)
Dr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud of
Feedback on using driver station software on another machine
I was wondering how many teams this past year decided to use a different machine to house their diver station software, and what your input would be for those looking to possibly do so this year.
Unread 05-10-2011, 16:29
Re: Feedback on using driver station software on another machine
Get as many built-in USB ports as you can.
Avoid Windows 7 Starter (but it will work okay with some tinkering).
Unread 05-10-2011, 20:14
O'Sancheski O'Sancheski is offline
O'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond repute
I can remember us having to do this at WPI because our classmate overheated and wouldn't reboot. So we found a students netbook and used that for the rest of the regional and it worked fine.
Unread 06-10-2011, 01:40
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
Just any decent and stable machine. Doesn't over heat, lots of USB, enough CPU for vision processing if you need it. For example we just had camera lag, just by viewing on the Netbook, while on a i5 laptop it played back fine.
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
Unread 06-10-2011, 10:33
Roger Roger is offline
FRC #1153
Rookie Year: 1900
Roger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond repute
There is one extremely rare bug, if you use a non-classmate computer, that did not get discovered until our team went to the Mainely SPIRIT event this past September. Rare, in that it involves (1) a non-classmate computer with the driver station software installed; (2) the off-season FMS (though, come to think of it, maybe not); and (3) the (approximately) 39 teams that are numbered in the 1100s. Until it was proved at Maine (using the Field Management team doing debugging -- thanks everyone! -- and multiple borrowed laptops), we were convinced it was our Dells that were a problem. It turns out that for whatever reason any 192.11.yy.zz connections were ignored by the FMS.
Otherwise, I'm sure any machine that can take the DS software will work.
Unread 06-10-2011, 11:27
Kyler386's Avatar
Kyler386 Kyler386 is offline
I'm software, it's not my problem.
AKA: Ky
FRC #0386 (Team Voltage)
Kyler386 is an unknown quantity at this point
We had forgotten our classmate when we went to an offseason event. So, we used a student's laptop for practice. One thing to note is that the laptop will not connect to FMS unless the profile running on the laptop is named "Driver" (Or so we were told...)
Funny, the part of our LV code that looks nice doesn't work, but the code that is so horrid, you can't tell what's going on, works perfectly...
Unread 06-10-2011, 13:47
Anything beginning with 192 is going to be ignored, and quite properly so. The FRC control system uses IP addresses in the 10.xx.yy.zz range.
Unread 06-10-2011, 18:34
plnyyanks's Avatar
Data wins arguments.
AKA: Phil Lopreiato
Where, of course xx.yy is your team number (for me, 11.24) and zz is .05 (for the driver station)
Unread 07-10-2011, 13:28
FRC #1153
Rookie Year: 1900
My mistake. As I said there were FMS experts working on this and they tracked it down.
Until I hear differently, that classmate is our driver station.
Unread 07-10-2011, 14:30
mesamb1's Avatar
mesamb1 mesamb1 is offline
AKA: Sam Bacon
FRC #1466 (Webb Robotics)
mesamb1 is just really nicemesamb1 is just really nicemesamb1 is just really nicemesamb1 is just really nice
Read reviews about connecting to networks if your getting a new laptop.
I installed the driver station on my personal laptop(HP Pavilion dv5) for Smokey Mountain and ran into some network connection issues. However, it wasn't the program faults but the junk hardware that HP installed.
Dont forget that coding is light on the processor(I know many a team who code solely on their classmates). Battery life and USB ports are far more important, and your drivers would surely appreciate a large screen.
Unread 07-10-2011, 15:15
Dr Theta's Avatar
Lead Mentor
AKA: Derek Messer
Thanks everyone, this is great information.
