Go to Post It doesn't matter if students get inspiration from planning to creating to manufacturing to purchasing to watching to engineers creating the parts etc etc etc. As long as students are getting Inspired, FIRST is doing it's mission. - David Kelly [more]
Unread 07-10-2011, 15:56
Krestent Krestent is offline
Krestent is an unknown quantity at this point
How to attach Ultrasonic Sensor
Hi,
I can find no information on how the ultrasonic sensor is to be connected to the Cortex controller. I did find info suggesting that the Input cable is supposed to go to analog and the output cable is supposed to go to Digital, but no dice there. Is there something I'm missing?
Unread 08-10-2011, 10:35
DonRotolo's Avatar
Back to humble
FRC #0832
Re: How to attach Ultrasonic Sensor
Does this help?
http://www.vexrobotics.com/products/.../276-2155.html
Unread 10-10-2011, 16:34
That was the first place I looked. All info on thatpage shows how to connect the sensor to the old PIC controller. The confusion is that the Cortex does not have any ports labeled "Interrupt".
Unread 10-10-2011, 16:57
On the cortex, all digital ports may be used as interrupts. It's possible that your programming environment may have restrictions on what ports can be used with the ultrasonic sensor.
Unread 13-10-2011, 16:04
So I hooked up the sensor to Digital 6 and 7, hooked it up, and found that any time I program the sensor into a program using EasyC, the Cortex refuses to execute anything. Do I have a bad sensor?
