Go to Post Genius is one percent inspiration and 99 percent perspiration, which is why engineers sometimes smell really bad. - Koko Ed [more]
Unread 20-09-2011, 19:49
stem12bfalk stem12bfalk is offline
FTC #5178
stem12bfalk is an unknown quantity at this point
[FTC]: 4 wheel tank drive using Labview
We are trying to do 4 wheel tank drive. Two motors on the left and two motors on the right. We don't seem to be able to create a program that will use four wheels at the same time. What do we need to do to create a program to use 4 wheel tank drive.
Thanks
Unread 20-09-2011, 23:52
Christian Z's Avatar
Christian Z Christian Z is offline
FRC #2557 (Sota Bots)
Christian Z is an unknown quantity at this point
Re: [FTC]: 4 wheel tank drive using Labview
You can only make a two motor drive in the remote control editor. So what our team has done is that we generate a two motor drive code using the editor and then we just go into the "generated code" and add a motor to each motor block.
I know that sounds kind of confusing so if you have any questions just ask.
Unread 21-09-2011, 15:04
Scott_4140 Scott_4140 is offline
FTC #4140 (Fish in the Boat)
Scott_4140 is just really niceScott_4140 is just really niceScott_4140 is just really niceScott_4140 is just really nice
Just plug two sets of motor wires into each of the the two Tetriz motor controllers. As far as the software is concerned, you are driving two drive trains with one motor each. The rest is accomplished in Hardware.
Unread 08-10-2011, 11:24
FTC #5178
Thanks, we got tank drive working. We ended up connecting the left motors to arcade left and and the right motors to arcade right. It works so we're happy. Now we just have to figure out how to do 4 wheel drive during autonomous.
