Go to Post By the way, I will be running for office in 2008 .... - Paul Copioli [more]
Go Back   Chief Delphi > Announcements
Unread 08-12-2002, 11:25
Brandon Martus's Avatar Unsung FIRST Hero
Brandon Martus Brandon Martus is offline
busy.
AKA: B. Slash Kamen
Brandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond repute
Send a message via ICQ to Brandon Martus Send a message via AIM to Brandon Martus Send a message via Yahoo to Brandon Martus
Spell Check
There is now a spell checker. It's not going to catch every mistake, but it should grab a number of them. It's pretty self-explanatory, but if you need help, reply here.
Brandon Martus
e-mail
Unread 08-12-2002, 11:50
srawls's Avatar
srawls srawls is offline
#0122 (Nasa Knights)
srawls is an unknown quantity at this point
Send a message via AIM to srawls
When I click the button, nothing happens, even though I inserted a few spelling mistakes. What action is it supposed to take? (i.e. alert you, silently fix, etc.)
Stephen
PS.
This is a test for the spellcheker.
Unread 08-12-2002, 11:55
busy.
AKA: B. Slash Kamen
Click the button, a pop-up should appear. Your text will be in there, and all mis-spelled words will be in a drop-down, with correct spelled suggestions. Change them, hit 'check again' and then 'Finish Checking'. If it looks OK, hit 'Insert in Document',. and it will replace your previous text with the corrected text.
Brandon Martus
e-mail
Unread 08-12-2002, 11:57
srawls's Avatar
Ah, ok. I disable pop-ups in Opera, so that's why I didn't notice anything happening.
Thanks,
Stephen
Unread 08-12-2002, 12:02
Joe Matt's Avatar
Joe Matt Joe Matt is offline
Wake Up Get Up Get Out There
Joe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond repute
Thanks!
Unread 08-12-2002, 14:17
MattK's Avatar
MattK MattK is offline
Tap it.
MattK is a splendid one to beholdMattK is a splendid one to beholdMattK is a splendid one to beholdMattK is a splendid one to beholdMattK is a splendid one to beholdMattK is a splendid one to beholdMattK is a splendid one to beholdMattK is a splendid one to behold
Send a message via AIM to MattK
TANKS! I reilley nead thus
The views expressed in my posts are Mine and mine only.
my myspace!
Unread 08-12-2002, 14:38
Jack's Avatar
Jack Jack is offline
FIRST Scouting Network
AKA: Andrew Schenk
FRC #0201 (The FEDS)
Jack is a jewel in the roughJack is a jewel in the roughJack is a jewel in the rough
Send a message via AIM to Jack
Oh! But now i don't have the excuse of not spelling good. (To lazy)
Read my sig
PS: What 'service' are you using? Or, is this a hack that you found. (More with the word db, and not how the actual code works)
Team 201 - 2003 Great Lakes Semifinalists & 2003 Archimedes Division Finalists :|: Webmaster of www.feds201.com -> FBI Scouting
Winner of The 2003 ChiefDelphi Web Award for: User That Started The Most Non Chit Chat Threads
Winner of: 2003 FIRST Ventures with 5451.68 End Points
All about me: http://knehcsa.vze.com
**Check out the New FIRST Scouting Network**
Unread 08-12-2002, 15:40
busy.
AKA: B. Slash Kamen
It is a perl script that uses 'aspell' [link]. The only thing I modified with vBulletin was adding the button that sent your message to the perl script via javascript, which in turn sent back the corrected version, and placed it back into vBulletin. Probably very easy to add on to phpBB2, if of course you can install aspell on your server.
Next task: find out how to add words to the dictionary; or at least use 2 dictionaries. (1=english, 2=FIRST)
Brandon Martus
e-mail
Unread 08-12-2002, 17:18
Jack's Avatar
AKA: Andrew Schenk
Ya. That's the only downside. When i posted some 'tech' terms, it didn't know them. If i have time, i might put it on our forums. I don't think it will be used too much though. (Me opens up word and checks spelling of word )
Unread 08-12-2002, 19:34
busy.
AKA: B. Slash Kamen
If I can find a way to add words, I will make a page where you can submit words to add. Approval-based, of course.
Brandon Martus
e-mail
Unread 08-12-2002, 19:42
rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
Well, I don't know how you could do it dynamically, but you can always build your own dictionary using the "create" option to aspell. Here's the official site to look at for details: http://savannah.gnu.org/download/asp...00000000000000.
The only real problem I see is that there is no way to add an individual word; you have to create a whole new dictionary based on some "master" dictionary and a user-defined word-list. I suppose you could just keep copy of the plain-text word-list around and rebuild the dictionary every few days using the official English dictionary as your base.
--Rob
Unread 08-12-2002, 20:59
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Brandon, do you think you could try finding a 'stupid check' hack for VBulletin?
"I'm sorry, but your post is exceptionally stupid. Please try again in a few minutes."
I think it'd be valuable addition.
--Madison--
...down at the Ozdust!
Unread 08-12-2002, 21:04
Joe Matt's Avatar
Like the 459385 thread if the next years play will include water?
Unread 09-12-2002, 16:48
Kris Verdeyen's Avatar
Kris Verdeyen Kris Verdeyen is offline
LSR Emcee/Alamo Game Announcer
FRC #0118 (Robonauts)
Kris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond repute
Thumbs up Hooray for computers
Awesome. This will go a long way in improving the readability of some of these forums. Way to go, Brandon.
...Only a few people are awake and they live in a state of constant total amazement. -JP Shanley, Joe vs. the Volcano
Unread 10-12-2002, 01:33
Greg Ross's Avatar
Grammar Curmudgeon
AKA: gwross
FRC #0330 (Beach 'Bots)
Re: Hooray for computers
Do you think the worst offenders will use the spell check?
Check out Team857.com Jmoo Website Design/Showcase 10 30-06-2003 13:56
Team 245 Forums: Check them out.. Kevin Smith Website Design/Showcase 1 27-02-2003 22:09
OOps We need a spell check!!! Elgin Clock Dean Kamen's Inventions 12 06-07-2002 13:38
Check out the SoCal regional scores! archiver 2001 2 24-06-2002 02:43
WDW Park Hopper Passes-How to check joe_balint General Forum 19 21-05-2002 16:28
