Go to Post Thinking can be uncomfortable, but I always think that it is beneficial. - JaneYoung [more]
Unread 11-10-2011, 21:13
Kovs's Avatar
Kovs Kovs is offline
FRC #1259 (Paradigm Shift)
Kovs will become famous soon enough
Re: Debugging Techniques
I do not know if this will solve your problem, but for me the cRIO will only outputs to the compiler or debugs if it has a static ip address. (Windows has a dynamic ip address by default) When using a dynamic ip address, our computers never get past the "Waiting for cRIO to reboot (##s)"
Info on setting up static ip address
You should set your ip address to: 10.XX.YY.ZZ
(XX.YY is team number [123 -> 01.23] ; change ZZ so that no two computers on the network share the same address)
Unread 19-10-2011, 01:43
twiggzee twiggzee is offline
FRC #3502 (Octo-(PI)-Rates)
twiggzee is an unknown quantity at this point
we have been able to deploy code so that means our ip address should be set up correctly. also, as i mentioned i CAN run the debugger via an ethernet cable, just not wirelessly.
i was watching the java 101 kickoff workshop video recently (posted on the first website) and in the powerpoint presentation, the speaker mentioned that they were having problems getting the wireless debugger to work. maybe it's an issue with first that's not been solved yet??
Wendy
Team 3502
Unread 19-10-2011, 18:27
Kovs's Avatar
I guess I wasn't clear on what I was saying for what happens (at least for me) when using wireless: You can still deploy with a dynamic ip address, but you need a static ip address for println() and debugging.
Unread 19-10-2011, 18:41
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
I'm not sure what you are basing this claim on, but it's not accurate. It is the case that for debugging you need to configure the IP address (regardless of how it is assigned) in the target connection to debug.
-Joe
Unread 20-10-2011, 19:45
Kovs's Avatar
As I said in my posts: from my own experience deploying/debugging.
Could you please explain this more completely? (Specifically how to do this without a static ip address)
Unread 20-10-2011, 19:52
~Cory~'s Avatar
~Cory~ ~Cory~ is offline
Student
AKA: Cory Rypkema
FRC #0706
~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold
Our wireless solution is a 100 foot Ethernet cable.
corin.rypkema.org
WPI Class of '17
'12 Dean's List Finalist, Mentor of 706 - Cyberhawks
Unread 21-10-2011, 20:07
NetConsole (the basis of prints) broadcasts, so the IP doesn't matter.
