Go to Post So please, think twice before you click that little button that says "reply". - Ken Leung [more]
View Poll Results: Which is better: Performance wheels or Plaction wheels?
Performance Wheels 14 48.28%
Plaction wheels 15 51.72%
Voters: 29. You may not vote on this poll
Unread 11-10-2011, 23:26
Andrew Lawrence
Posts: n/a
Performance wheels vs. Plaction wheels
Which do you prefer: Performance wheels or Plaction wheels? Why do you like one over the other?
Thanks!
Unread 11-10-2011, 23:39
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Re: Performance wheels vs. Plaction wheels
Better how?
Plaction price is right and they perform well but performance wheels are cooler.
Unread 12-10-2011, 00:04
Andrew Lawrence
Posts: n/a
Originally Posted by IndySam View Post
Better how?
Better overall, in your opinion. And I agree, performance wheels have that coolness factor about them.
Unread 12-10-2011, 01:32
Ankit S.'s Avatar
Ankit S. Ankit S. is offline
FRC #2489 (The Insomniacs)
Ankit S. has a spectacular aura aboutAnkit S. has a spectacular aura about
Edit 2: Disregard what follows, I thought performance wheels were something else.
For some reason, I just like the plaction wheels. For that same reason, i just don't like performance wheels. I can't explain it, but i think i like plaction wheels because they are great in traction, size, and weight. I think i dont like performance wheels because I prefer mechanums over them to do fancy tricks...
Now don't get me wrong, they both(performance vs plaction) have their advantages and disadvantages, but imo, plaction all the way <3.
EDIT: Ill think about why its like this, and if you want a better answer, hit me up at CalGames .
FRC 2489 - The Insomniacs
Alumnus
2489, 3189, & 701 - The Green Alliance - 2013 Sacramento Regional #6 Alliance Captain and Champions!!!
971, 254, & 2489 - 2011 CalGames Champions. Thanks 254 and 971!!!
Last edited by Ankit S. : 12-10-2011 at 21:03. Reason: Thought Performance wheels were something else...
Unread 12-10-2011, 01:34
Plaction vs Performance has nothing to do with what you mean by fancy tricks.
Your tread it what gives you traction, not the wheel the tread goes on.
Unread 12-10-2011, 03:52
msimon785 msimon785 is offline
Fusing Function with Form
AKA: Mathew Simon
msimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant future
Exactly. There is absolutely no difference in terms of traction. The CoF will remain subject to the tread riveted TO the wheel. The way I see it, this is an aesthetics vs cost question. While the Performance wheels have an obvious aesthetic advantage - this is undeniable, - they cost $36 / piece (with bearings). This is compared to $26 for the Plaction wheels.
In my personal opinion (and I should say that I will almost always be biased towards aesthetics), they $10 per wheel extra to get the aluminum Performance wheels is definitely worth it. Compared to the overall cost of your robot, $10*[# of wheels] is probably a minute amount of money.
That said, there are definitely situations, ie. a practice bot, in which case there would be no reason for the additional expenditure, given that the robot will likely never be in the public eye.
Just my 2 cents.
Mathew Simon
CAD/Design
[2013-20xx]: 973 "Greybots"
[2011-2013]: 1515 "MorTorq"
[2008-2010]: 1836 "MilkenKnights"
Unread 12-10-2011, 04:07
It is not all aesthetics.
The plaction wheels are easier to use in a drive setup in which sprockets are mounted to either side of the drive wheel whereas performance wheels with hex or key in them are easier to use for let's say a WCD system. Performance wheels have a bolt pattern on only 1 face, so you would have to double mount sprockets in order to run the most common 6wd setup. Each wheel has its benefits. The plaction wheels require a hub if you wish to direct drive, where the performance wheels are broached if desired.
It depends on what you are designing, there's no real "which is better?" in most cases of wheel selection. Tread selection is another issue though.
Unread 12-10-2011, 09:31
Andrew Lawrence
Posts: n/a
Thanks for all of the answers so far! We were thinking of performance wheels because of two reasons: They look nice, and one of our placation wheels cracked last year (resulting in little to no control one match at SVR and then running over our own minibot someone knocked off. )
Unread 12-10-2011, 12:29
AcesJames's Avatar
AcesJames AcesJames is offline
Mentor, still learning
AKA: James Temple
FRC #2170 (Titanium Tomahawks)(EWCP)
AcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond repute
Send a message via AIM to AcesJames Send a message via MSN to AcesJames
176 used plaction wheels for the first time in 2011, and we noticed that the little edging that runs along the outside of the wheel that holds the tread in place started to snap off after our first regional. This, of course, eventually led to tread just moving sideways and falling off the wheels. We saw instances of this on all 6 wheels on our drivetrain. So, we ended up replacing all 6 wheels.
In 2012, if our drivetrain is conducive to the use of wheels which use tread, we will most likely use performance wheels. 6 x $36 is much cheaper than 12 x $26. Just something to think about. Of course, if you want to get into which wheel is easier to mount on a certain kind of drivetrain, see Akash's post above.
FRC 176 - Aces High - 09-12 - Student
FRC 229 - Division By Zero - 13-14 - "Mentor"
FRC 2170 - Titanium Tomahawks - 17-Now - Mentor
Unread 12-10-2011, 12:34
Chris is me's Avatar
AKA: Pinecone
This isn't entirely true. We had measurably more traction from our Performance 4 inch wheels than our Plaction 6 inch wheels. I suspect it has something to do with the Plaction's deep tread groove.
Unread 12-10-2011, 13:01
Nemo's Avatar
Nemo Nemo is offline
Team 967 Mentor
AKA: Dan Niemitalo
FRC #0967 (Iron Lions)
Nemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond repute
For a directly driven wheel, a performance wheel is cheaper and lighter than a plaction wheel + AndyMark hub.
Unread 12-10-2011, 13:14
Mr. B's Avatar
Mr. B Mr. B is offline
FRC #5122 (RobOTies)
Mr. B is an unknown quantity at this point
We had the same problem as team 176 listed above. Wire ties and rivits helped us get through the competition
Unread 12-10-2011, 14:09
jwfoss jwfoss is offline
Chasing Elegant Simplicity
AKA: Justin Foss
Both wheels fall into the same category: COTS wheels with replaceable tread. This category also contains the IFI/VEXPro wheels. They all provide the ability to mount up treads of your choice.
For prototyping purposes a set of Plaction wheels will allow you to try different axle sizes (1/2" or 3/8") by switching just the bearings and testing live vs. dead axles (hex or keyway) with the addition of hubs.
I like the flexibility in testing that Plaction wheels offer, but for a competition robot with a defined drivetrain the Performance wheels would be my choice (that is, if i wanted treaded wheels and was happy with only a 1" tread width)
Unread 12-10-2011, 14:15
AKA: Pinecone
FWIW, IFI wheels are pretty much the same in this regard.
Unread 12-10-2011, 14:51
Colin P's Avatar
Colin P Colin P is offline
MTU Robotic Systems Enterprise
AKA: Colin Putters
FRC #0857 (Da Yooper Troopers 3771, Unbolted Puppeteers 4363)
Colin P is a splendid one to beholdColin P is a splendid one to beholdColin P is a splendid one to beholdColin P is a splendid one to beholdColin P is a splendid one to beholdColin P is a splendid one to behold
You would've been getting more torque from a 4 inch wheel than a 6 inch wheel, but I'm going to assume you knew that and agree with you that performance wheels edge out the plaction wheels due to that groove design.
