Go to Post Don't put any weight into the OPR. It's ugly and its momma dresses it funny. - wilsonmw04 [more]
Unread 12-10-2011, 07:57
Phyrxes's Avatar
Phyrxes Phyrxes is offline
Has done the math, have you?
AKA: Dave Button
no team (No Team, Changed Schools)
Phyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant future
Re: Robot plexiglass/plastic
We have ordered from http://www.eplastics.com/ in the past but generally make one large order a year to save on shipping anything that can't be rolled up and shipped in a tube.
Dave Button
Physics and Mathematics Teacher
Wakefield School
The Plains, VA
“Simplify and add lightness.”
― Colin Chapman, Team Lotus
Unread 12-10-2011, 08:10
Gdeaver Gdeaver is offline
FRC #1640
Clear PETG is known as the poor man's polycarb. Not as good as poly carb but should be acceptable for some robot apps.
Unread 12-10-2011, 08:21
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Has anyone ever tried applying automotive style window tint to Acrylic sheet and then seeing if it will shatter like an un-tinted sheet?
My gut tells me that the tint should help hold the broken shards of Acrylic together should they crack, I'm just wondering if this is actually true...
-Dustin Benedict
Unread 12-10-2011, 08:30
Andy Baker Andy Baker is online now
President, AndyMark, Inc.
FRC #3940 (CyberTooth)
Originally Posted by Burt65 View Post
// spam post deleted //
Anyone using acrylic or plexiglas on a FIRST Robotics Competition robot is just asking for trouble, as it shatters. MANY people refer to the clear plastic (polycarbonate) used on these robots as plexiglas, which is incorrect, as stated many times in this thread.
Here is a very simple way to tell the difference between two pieces of clear plastic, of which one is acrylic and the other is polycarbonate: look at the outside edge of the plastic sheet. If the outside edge has a blue tint, then it is polycarbonate. If this same edge is white or frosty-clear, then it is acrylic.
Then, put the acrylic back up on the shelf (or throw it away*) and next take the polycarbonate in your arms and give it a big hug.
Here is a pretty good discussion we had about this same topic a few years ago.
Sincerely,
Andy Baker
* I'm actually serious about this. There is no need to have any trace of sheet acrylic in a robot-building shop. If you just put it back up on the shelf, you might as well write on it with a sharpie marker "Don't use this acrylic stuff - it shatters!!!"
Last edited by GaryVoshol : 12-10-2011 at 14:19. Reason: The rest of Andy's remarks are pertinent, even after deleting the spammer.
Unread 12-10-2011, 09:01
Phyrxes's Avatar
AKA: Dave Button
So do it yourself laminate, possibly on both sides, to contain the plastic should it take an impact? Not sure its worth it even for display purposes as it will still likely get dropped by a student carrying it.
Dave Button
Wakefield School
The Plains, VA
Unread 12-10-2011, 09:59
Brandon Holley's Avatar
Just curious as to what the point would be? If you are going to put tint on to a sheet of plastic anyway, why not just use PC?
-Brando
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
Unread 12-10-2011, 10:27
Chris is me's Avatar
AKA: Pinecone
It's at least easier to laser cut, which can be useful in some applications.
Unread 12-10-2011, 13:23
I should add, being the capitalistic guy that I am, you can now buy 2 ft. x 2 ft. square sheets of polycarbonate plastic from AndyMark in these thicknesses:
Thank you,
Andy B.
Unread 12-10-2011, 13:31
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (Red Pride Robotics)
Thank you,
Andy B.
It would be very cool if these items were made available through FIRST Choice.
Hi!
Unread 12-10-2011, 13:48
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
We often prototype with acrylic -- it's much cheaper and easier to laser cut, so we can throw things together quickly. It's very rare -- though not unheard of -- that acrylic ends up on our finished robots, though.
--Madison--
...down at the Ozdust!
