Go to Post sometimes you have to put up with the rain to see the rainbow - Beth Sweet [more]
Unread 13-10-2011, 09:49
Brandon Holley's Avatar
Re: [DFTF] Brave Pneumatic World...
Originally Posted by Joe G. View Post
Plastic air tanks were quite big last year...I know 217, 148, 1114, 125, and others used them to great effect. This thread has some good information.
We actually didn't use the plastic tanks this year...we used one big tank
You can see it below, underneath our minibot deployment. We used this one tank with the new compressor and had no issues through the entire season. The compressor hardly ever had to turn on with the size of the tank, even with a pneumatically actuated wrist and shifting drive train.
We also used a pneumatic manifold block that I'm trying to find the part number of. It was made by SMC. This type of manifold simplified our lives so much that we will never use pneumatics without one again. It allowed for clean plumbing of the system, and even allowed for additional ports at the ready if we ever needed to add something later on. I will report back when I have the exact part number because it really is the smartest thing you can do for your pneumatic system.
The rules have really only opened up in the past 2 years, so you are not that far behind the 8 ball on that front. I've heard rave reviews about the plastic tanks mentioned above. I will also chip in our rave review for one large tank if you can find a place to put it. The new pump can have it's issues with duty cycle and overheating, but we personally did not encounter those issues.
-Brando
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
Unread 13-10-2011, 10:03
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Just so we're all clear, storage tank size will not change the duty cycle of your compressor, compressed air use determines the duty cycle of the compressor. It is a simple energy balance.
Increasing pneumatic storage volume only increases the time between the compressor shutting off and turning back on again. The length of time the compressor runs for to bring the storage system back up to full pressure is proportionally longer. IMO the smallest effective storage system is best.
In fact, if you're completely venting the pneumatic system storage after a match (as one should for safety reasons) a larger storage volume will take longer to recharge from 0. A larger storage tank will wear the compressor more because all of the stored energy is wasted.
In 2011 we used pneumatic shifters, a pneumatic telescoping arm, and a pneumatic wrist joint. Four KOP tanks were more than adequate. We probably could have used just 2 or 3.
Unread 13-10-2011, 10:20
All of what you are saying is true. For us however, the compressor only needed to turn on in the last 30 seconds of the match (if at all). Sure it took a while to pre-fill the tanks, but that was all apart of the pre-match routine. We were actually quite confident we didn't even need a compressor with the volume of tank we had. However, we had the weight and decided to add it in towards the end of our build as a safety. We encountered no issues with compressor life.
-Brando
