Go to Post Unfortunately our team missed out on a great opportunity to "learn from the pros" because we did student-centric things like insisting on having a student field coach. - Tom Bottiglieri [more]
Unread 13-10-2011, 02:25
penguinfrk's Avatar
penguinfrk penguinfrk is offline
AKA: Larry
FRC #1899 (Saints Robotics)
penguinfrk is a glorious beacon of lightpenguinfrk is a glorious beacon of lightpenguinfrk is a glorious beacon of lightpenguinfrk is a glorious beacon of lightpenguinfrk is a glorious beacon of lightpenguinfrk is a glorious beacon of light
Simple method for controlling CIM speed?
For our senior float, we're trying to make an inflatable Harry Potter doll revolve around a paper mache snitch.
A really quick model of it can be found here: http://www.youtube.com/watch?v=MFJ9R2tNFrQ. I apologize for the low quality video.
To power it, we have two CIM motors on a Toughbox Mini sharing one output shaft. There's an idler wheel for support.
Is there a good, simple way to regulate the speed of the motor? We need to slow it down further than the gear reductions due to safety issues with our administration. It doesn't have to be a mechanical solution.
We're thinking of using jaguars right now, but none of my team's seniors are on programming, so we're pretty in the dark about how to do it. We don't need it to be remote controlled; the system can be powered as soon as the breaker is flipped. Which electrical components will we need (are the cRIO, sidecar, power distribution board, etc. all necessary)? What programming would be necessary?
Thanks for the help!
Larry
Saints Robotics 1899
High school intern at FIRSTWA
2011 Seattle Olympic Regional:
Website Excellence, FIRST Dean's List Award (for team captain Kevin Kimura), Tournament Winner (Thanks 3393 and 2990!), Chairman's Award Winner
Unread 13-10-2011, 03:34
Jeremy Germita's Avatar
Jeremy Germita Jeremy Germita is offline
Co-Advisor/Lead Engineering Mentor
AKA: wood is good. plastic is fantastic.
FRC #5012 (Gryffingear) / (Antelope Valley FIRST Teams)
Jeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond repute
Re: Simple method for controlling CIM speed?
I have a no-programming-involved solution....
You could use a jaguar, or any motor controller with a PWM input. And build the servo controller circuit below.
The Jaguar and Victor can take in any standard servo signal input, they just need to be calibrated. Since you are not using the full range, this may not be necessary...
Since you are using 2 motors, I recommend you use a PWM Y cable to split the signal to the two controllers.
image credit 555-timer-circuits.com
This solution will keep costs low and let you keep the PDB, cRIO, and other elements.
The only modification to the circuit is that you need a 5 volt regulator for the circuit. you can connect this directly to your power supply and it will start moving at the set speed as soon as you power on.
Please! I cant stress enough the importance of safety. Test this without any load on the shaft first, then when you have your desired speed, fix the load onto it.
If you have any questions about this, ask away.
Jeremy G.
Drive Coach Team 5012 Gryffingear / Antelope Valley FIRST teams / EWCP - (2013 - Current)
Student / Driver / Programmer / CAD - FRC Team 399: Eagle Robotics / FTC Team 72: GarageBots - (2009 - 2013)
Los Angeles Region FTC FTA/CSA/Head Ref
[FF] FIRST Pick
2014 FTC Los Angeles Regional Compass Award Winner.
2017 - San Diego Regional / Sacramento Regional / Las Vegas Regional
2016 - Los Angeles Regional Creativity + Winners (1197, 987, 5012) / Las Vegas Regional Team Spirit + SF (5012, 5851, 5049) / Galileo Subdivision
2015 - Inland Empire QF (597, 5012, 4413) / Las Vegas Imagery + Winners (148, 987, 5012) / Newton Subdivision and World Champions (118, 1678, 1671, 5012)
2014 - Inland Empire Rookie All Star + Highest Rookie Seed + SF (2339, 1967, 5012) / Las Vegas Rookie All Star / Galileo Division Imagery
Unread 13-10-2011, 06:19
Ninja_Bait's Avatar
Ninja_Bait Ninja_Bait is offline
Former Prez of Making Things Go
AKA: Jake Potter
FRC #0694 (StuyPulse)
Ninja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond repute
Or you could just use a weaker battery than the 12v FRC monsters.
You can't fix something that isn't broken... but you can always break things that aren't fixed!
Unread 13-10-2011, 07:56
JamesCH95's Avatar
JamesCH95 JamesCH95 is online now
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Or even a 6V battery.
Unread 13-10-2011, 08:35
Wire the two CIMs in series and connect them to a 12volt auto battery.
Unread 13-10-2011, 10:37
nighterfighter nighterfighter is offline
1771 Alum, 1771 Mentor
AKA: Matt B
FRC #1771 (1771)
nighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant future
You could also use an Arduino's PWM output feature to control either a Victor or Jaguar, so you can control its speed more accurately. That also elminates the need to use the cRIO. Unless of course you need it for something else.
Unread 13-10-2011, 10:54
MrForbes's Avatar
AKA: Jim
FRC #1726 (N.E.R.D.S.)
buy a servo tester.
http://www3.towerhobbies.com/cgi-bin...ster&search=Go
Unread 13-10-2011, 11:40
Chris is me's Avatar
AKA: Pinecone
A Victor and a Vex controller.
Unread 13-10-2011, 12:08
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
Simplicity at its best. There is no need for fancy and expensive controllers.
Unread 13-10-2011, 12:51
MrForbes's Avatar
AKA: Jim
An advantage of using a speed controller is that you can set the speed nice and slow for the safety demo, then speed it up for "real life"
