Go to Post Who would have thought a triangular robot would fit into a triangular goal :rolleyes: - Wayne Doenges [more]
Unread 13-10-2011, 22:53
h1n1is4pigs's Avatar
h1n1is4pigs h1n1is4pigs is offline
h1n1is4pigs has a spectacular aura abouth1n1is4pigs has a spectacular aura about
monitoring air pressure
i was wondering if there was a sensor out there that we could use to find the pressure of our pneumatics and take that pressure and make it available for use in the code. if you know of one that is relatively cheap and works decently it would be much appreciated. thanks in advance
Unread 13-10-2011, 23:12
Re: monitoring air pressure
Well, there is one. IIRC, it's included in the KOP. It's definitely required if you're going to use pneumatics (<R72> in the 2011 rules). It goes into the code, and if the pressure is too low, the compressor turns on.
If you need something more than that, you can refer to the same sensor. Note that it is on the high-pressure side of the circuit, so you may also want one for the low-pressure side, but that's your choice (and you could reasonably expect a more detailed inspection due to having two sensors--which one really runs the compressor and all that sort of thing).
Unread 14-10-2011, 00:59
feverittm's Avatar
feverittm feverittm is offline
FRC #0997 (Spartans)
feverittm will become famous soon enoughfeverittm will become famous soon enough
This isn't entirely correct. They include a pressure switch not a pressure transducer. Supposedly TI donated one a number of years ago, but I have yet to find it.
I am also very interest in the answer to this question.
Thanks
Floyd Moore
Mentor Electrical and Pneumatics
Team 997 - Spartan Robotics
Corvallis High School, Corvallis Oregon
Unread 14-10-2011, 02:37
Jeremy Germita's Avatar
Jeremy Germita Jeremy Germita is offline
Co-Advisor/Lead Engineering Mentor
AKA: wood is good. plastic is fantastic.
FRC #5012 (Gryffingear) / (Antelope Valley FIRST Teams)
Jeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond repute
We have a TI pressure transducer from 04, if I am correct. The voltage is proportional to the pressure.
According to this post, the model number is TI 5CP3-7.
Drive Coach Team 5012 Gryffingear / Antelope Valley FIRST teams / EWCP - (2013 - Current)
Student / Driver / Programmer / CAD - FRC Team 399: Eagle Robotics / FTC Team 72: GarageBots - (2009 - 2013)
Los Angeles Region FTC FTA/CSA/Head Ref
[FF] FIRST Pick
2014 FTC Los Angeles Regional Compass Award Winner.
2017 - San Diego Regional / Sacramento Regional / Las Vegas Regional
2016 - Los Angeles Regional Creativity + Winners (1197, 987, 5012) / Las Vegas Regional Team Spirit + SF (5012, 5851, 5049) / Galileo Subdivision
2015 - Inland Empire QF (597, 5012, 4413) / Las Vegas Imagery + Winners (148, 987, 5012) / Newton Subdivision and World Champions (118, 1678, 1671, 5012)
2014 - Inland Empire Rookie All Star + Highest Rookie Seed + SF (2339, 1967, 5012) / Las Vegas Rookie All Star / Galileo Division Imagery
Unread 14-10-2011, 03:14
ratdude747's Avatar
Official Scorekeeper
AKA: Larry Bolan
analog pressure sensors -they do exist... Actually, my old team (2783) had one for the 2010 bot that was never installed, and as part of my restoration project, I connected it tot he low (60psi) side of the air circuit. IIRC, it was a $50 part.
be careful, as this sensor was only rated for 100 PSI, the original intended use was on the high side, which would have killed it.
electrically, it used a 12v input. it had an output of 0-5v, with 5v=100 PSI.
pnumatically, it was put right after the output of the 60 PSI regulator
Code wise, IIRC (it has been a while since I re-wrote the code), it first multiplied the voltage by 20 to render the PSI, then I used that number to disable the kicker (only thing pnuematic) if the PSI was over 65 or below 40, as low pressures would jam the solenoids. the actual pressure and over/under data was sent to the dashboard, where the pressure had both a gauge and actual readout. The over/under pressure signals were routed to colored lights on the dash (over red, under green).
I attached the labview source code for the dash and robot (and the dash .exe) for those who want a look at the implementation.
Unread 14-10-2011, 07:17
Chris_Elston's Avatar
Chris_Elston Chris_Elston is online now
Controls Engineer
AKA: chakorules
FRC #1501 (Team THRUST)
Chris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond repute
We have used an SMC one in the past that has an ANALOG output. So we could scale the PSI in the code. It also had a nice digital read out.
http://www.smcetech.com/CC_host/page...65c156a221d 4
In 2007, air was really important for us.
ID:	10987  Click image for larger version
Team T.H.R.U.S.T. 1501
Download all of our past robot's source code here:Repository
Favorite CD quote:
"That can't be their 'bot. not nearly enough (if any) rivets to be a 1501 machine." ~RogerR: Team #1369
Unread 24-10-2011, 17:12
jreuter jreuter is offline
FRC #1073 (Force Team)
jreuter has a spectacular aura aboutjreuter has a spectacular aura about
Team 1073 has used SSI 5V (0.5 to 4.5V output) analog pressure transducers.
Digikey has a good selection in the $68 range.
I think we used the 300 psi rated part, just to avoid any argument with the inspectors. This reduced our accuracy in the 0 to 60 PSI range we were working with, but it wasn't a problem for our application.
[url="http://onlinecatalog.digikey.com/WebProject.asp?CodeId=7.4.4.32&pagelabel=2744"]
Unread 25-10-2011, 09:26
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
FYI
Texas Instruments no longer owns that company. If you want to buy that part you have order it through Sensata Inc.
The make a variety of pressure tranducers from 0-10 Volt ratiometric output.
I've used them at work over the years.
Thank-you 294 & 67
www.bobcatrobotics.org
