Go to Post I didn't say this! - Max Lobovsky [more]
Unread 14-10-2011, 11:57
Greg Shaw's Avatar
Greg Shaw Greg Shaw is offline
FRC #3601
Greg Shaw is a jewel in the roughGreg Shaw is a jewel in the roughGreg Shaw is a jewel in the rough
CRIO FRC II Questions
I am am mentor for a second year FRC Team (3601). I have some questions abouit the new CRIO:
1) Last year we only used 2 of the modules on our CRIO--are there situations that require using more than 2 modules--5 modules are provided.
2) To save money, we are thinking about purchasing a CRIO FRC II chasis and putting our extra 3 modules from last years CRIO into the new CRIO--will this work? Can we use the old modules with the new CRIO Chasis??
Unread 14-10-2011, 12:26
Re: CRIO FRC II Questions
The old modules are the same, so they will work fine in the new cRIO FRC II.
Basic operation just requires one Analog and one digital module.
The solenoid module can also be used if you add pneumatics to your robot.
Depending on the robot year, we've used from 2 to 4 modules.
Unread 14-10-2011, 12:29
You must use at least one Analog In and one Digital I/O module. If you want to read more than seven analog values, you need a second Analog module. If you want more PWM outputs or more digital I/O than the Digital Sidecar provides, you need a second Digital module. If you want to control pneumatic solenoid valves directly (not through a Spike relay), you need a Solenoid (Digital output driver) module, and you might need two if you have enough pneumatics.
But for most teams, a single Analog In and a single Digital I/O is enough.
The same three module types (and only those module types) work in the new smaller FRC cRIO chassis. Buying only a bare chassis will be fine for what you want to do. But if you can manage to scrape up the money to buy the full cRIO kit as well, I don't think you'll regret having another cRIO available.
Unread 14-10-2011, 13:09
Colin P's Avatar
Colin P Colin P is offline
MTU Robotic Systems Enterprise
AKA: Colin Putters
FRC #0857 (Da Yooper Troopers 3771, Unbolted Puppeteers 4363)
Colin P is a splendid one to beholdColin P is a splendid one to beholdColin P is a splendid one to beholdColin P is a splendid one to beholdColin P is a splendid one to beholdColin P is a splendid one to behold
Yeah, the majority of teams only use 2 or 3 modules, so the 4 slot cRIO is going to be a perfect fit.
The four slot is going to be provided in the KOP, so you won't even need to purchase one.
Unread 14-10-2011, 13:14
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (Red Pride Robotics)
It will be in the rookie kit.
Hi!
Unread 16-10-2011, 22:11
Jeremy Germita's Avatar
Jeremy Germita Jeremy Germita is online now
Co-Advisor/Lead Engineering Mentor
AKA: wood is good. plastic is fantastic.
FRC #5012 (Gryffingear) / (Antelope Valley FIRST Teams)
Jeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond repute
Are the drawings available yet? Specifically the mounting hole locations and footprint?
Thanks,
Jeremy
Drive Coach Team 5012 Gryffingear / Antelope Valley FIRST teams / EWCP - (2013 - Current)
Student / Driver / Programmer / CAD - FRC Team 399: Eagle Robotics / FTC Team 72: GarageBots - (2009 - 2013)
Los Angeles Region FTC FTA/CSA/Head Ref
[FF] FIRST Pick
2014 FTC Los Angeles Regional Compass Award Winner.
2017 - San Diego Regional / Sacramento Regional / Las Vegas Regional
2016 - Los Angeles Regional Creativity + Winners (1197, 987, 5012) / Las Vegas Regional Team Spirit + SF (5012, 5851, 5049) / Galileo Subdivision
2015 - Inland Empire QF (597, 5012, 4413) / Las Vegas Imagery + Winners (148, 987, 5012) / Newton Subdivision and World Champions (118, 1678, 1671, 5012)
2014 - Inland Empire Rookie All Star + Highest Rookie Seed + SF (2339, 1967, 5012) / Las Vegas Rookie All Star / Galileo Division Imagery
Unread 16-10-2011, 22:33
slijin's Avatar
slijin slijin is offline
Pockets
AKA: Samuel Lijin
FRC #0694 (StuyPulse)
Thanks,
Jeremy
As far as I'm aware, this is the only such existing documentation that NI has on their website with regards to the cRIO II.
Mark's white paper notes that the new cRIO is 4.4” shorter in length, same height & width, with the dimensions 7”(l) x 3.5”(w) x 2.5”(h). It also says that the new cRIO will resemble the 9076, but I'm not sure about that and it doesn't list specs regarding screw placement anyways.
2010-12 CT Chairman's
2011 Galileo 5th seed
2010 NY Regional Winners
Unread 16-10-2011, 22:38
Thanks,
Jeremy
I think the 9075/6 should be close enough: http://www.ni.com/pdf/manuals/375650a.pdf
Unread 17-10-2011, 09:01
Definitely close enough. Those are the base models that the FRC option is based on.
Greg McKaskle
Unread 18-10-2011, 06:32
Eric222 Eric222 is offline
FRC #0222 (Tigertrons)
Eric222 is an unknown quantity at this point
Does anyone know what the USB port will be used for?
http://tigertrons.net/
Unread 18-10-2011, 06:35
The cRIO FRC II doesn't have the optional USB port.
