Re: CRIO FRC II Questions
Are the drawings available yet? Specifically the mounting hole locations and footprint?
Thanks, Jeremy |
Mark's white paper notes that the new cRIO is 4.4” shorter in length, same height & width, with the dimensions 7”(l) x 3.5”(w) x 2.5”(h). It also says that the new cRIO will resemble the 9076, but I'm not sure about that and it doesn't list specs regarding screw placement anyways. |
Definitely close enough. Those are the base models that the FRC option is based on.
Greg McKaskle |
Does anyone know what the USB port will be used for?
The cRIO FRC II doesn't have the optional USB port.
