Go to Post water electricity=bad - Chuck Glick [more]
Go Back   Chief Delphi > Technical > Programming > Python
Unread 14-10-2011, 01:15
Peter Johnson Peter Johnson is offline
WPILib Developer
Peter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud of
RobotPy 2011.3
As there seems to be a lot of interest in trying out Python in the fall, I've released a new (hopefully final) version for 2011: 2011.3
Download the new packages at: http://firstforge.wpi.edu/sf/frs/do/...ts.robotpy/frs
Note you want to download all three packages!
The "core" package contains Python (FRC_UserProgram.out) and its standard libraries.
The "WPILib" package contains WPILib - both the libraries for the robot and some sample code.
The "Utilities" package contains some useful utilities (contributed by virtuald).
Both the core and WPILib packages have "robot" directories containing the files that need to be copied to the robot. They also have an install.py Python script that will perform this copy for you (just enter your team number).
This version incorporates WPILib r2262 and some incomplete vision wrappers.
Author of cscore - WPILib CameraServer for 2017+
Author of ntcore - WPILib NetworkTables for 2016+
Creator of RobotPy - Python for FRC
2010 FRC World Champions (294, 67, 177)
2007 FTC World Champions (30, 74, 23)
2001 FRC National Champions (71, 294, 125, 365, 279)
Unread 14-10-2011, 02:03
virtuald's Avatar
virtuald virtuald is offline
RobotPy Guy
AKA: Dustin Spicuzza
Re: RobotPy 2011.3
Haha, I was just going to email you tomorrow about possibly releasing some new packages.
Unread 16-10-2011, 17:10
ozzloy ozzloy is offline
FRC #0812
ozzloy is an unknown quantity at this point
Re: RobotPy 2011.3
http://firstforge.wpi.edu/sf/wiki/do...y/wiki/Install
says "unzip the release .zip", there's 3 of them here:
my robot is flashed with c++.
i have downloaded all 3 files up there, unzipped them, and ftpd all files in {core,wpilib}/robot/* to 10.te.am.2:/*
i put a robot.py under 10.te.am.2:/py/robot.py next to boot.py
i get red next to Robot Code.
am i skipping a step?
Unread 17-10-2011, 00:25
virtuald's Avatar
RobotPy Guy
Re: RobotPy 2011.3
Yes, that's what you should have done. You should use the NetConsole and see if there are any errors reported when the robot is starting up.
Unread 19-10-2011, 00:42
FRC #0812
Re: RobotPy 2011.3
now that you've confirmed those steps, i'm running on a new theory.
i think flashing to c++ might not have worked correctly.
we've had it fail to switch before. i'm kicking myself for not thinking of it at the time.
now we're going to retry flashing until a the sample c++ program runs. then we'll load the python interpreter.
i'll let you know how that works this weekend.
i've talked to a couple people on other teams who also have had trouble flashing. is there something better than just retrying until it actually flashes? one guy suggested something about dip switches on the bot?
Unread 29-10-2011, 17:22
404'd's Avatar
404'd 404'd is offline
Lead contributor of sweg
AKA: Josh
FRC #0967 (Iron Lions (9-sits-7))
404'd is a name known to all404'd is a name known to all404'd is a name known to all404'd is a name known to all404'd is a name known to all404'd is a name known to all
Re: RobotPy 2011.3
Have you had any luck? Because i've been trying RobotPy, and i still get the no robot code light. Even the sample code wont run. I've formatted crio for C++ (v28 image), ran the install on both core and WPIlib, and copied over the "Simple" sample code, but i still have get no "robot code" light. I've seen some posts about using net console, so i will look into that next time i have access
Josh
Driving "Career":
2012 GKC: Quarterfinals w/ 6th seeded alliance | Wisconsin: Quarterfinals - 3rd seeded alliance captains
2013 GKC: Quarterfinals w/ 5th seeded alliance | North Star: Regional winners, 2nd seeded alliance captains
2013 CMP: Curie Semis w/ 2056 + 3990
Unread 29-10-2011, 19:08
virtuald's Avatar
RobotPy Guy
Re: RobotPy 2011.3
It's pretty much a necessity to have NetConsole enabled when you're using RobotPy. Otherwise you can't tell when things die.
