Go to Post Truly good teasers should give people a good place to start guessing, while still leaving some mystery and uncertainty. - Travis Covington [more]
Unread 18-10-2011, 21:59
ThaineP
Posts: n/a
What to get as a good first car
I'll be going to college in a few years, and may or may not need to get a car.
I've had my license a year now and use my mom's Honda Accord and my dad's Ford F-150, with the Accord in use most.
I thought I'd get an excessive head start on finding good car possibilities, so does anyone have any good suggestions? Note that I'd likely be buying used to save money, so unless the car is cheap new, try to stick to older models. I also despise SUV's, minivans, crossovers, and the like, too, due to personal taste.
This post can also be for anyone else who is unsure of what FIRST (haha) car to get.
So far I've found a few possibilities:
Honda Accord, Civic, Fit
VW Jetta
Mini Cooper
I don't really like American cars, apparently.
Unread 18-10-2011, 22:44
DonRotolo's Avatar
Back to humble
FRC #0832
Re: What to get as a good first car
First focus needs to be on safety. A new-enough car with at least anti-lock brakes and airbags, and larger rather than smaller. Check the IIHS and NHTSA safety ratings. Also, remember that in a collision, mass wins.
Second needs to be reliability. Stranded is a bummer, but it can be dangerous as well (first point)
Then check the classifieds or eBay for what kind of car you can get for the money you have. Keep $1000 aside (for a $5000 car) for repairs; nobody sells a perfectly fine car, regardless of the story.
If you're not a car expert, pay a mechanic or dealer $250-300 for a pre-purchase inspection. Not only will this prevent a serious error, you'll know what to spend the remaining money of your $1000 on. Safety things first (tires, brakes, steering system, suspension), reliability next.
ANY car with ANY rust should be crossed off your list, unless you expect to keep the car for only a year or 2. Or really have very little money. If the car has all the maintenance records, that means someone cared about it.
The last thing to consider is maintenance costs. You can buy a 1988 Mercedes 300E in good condition for $4k (both safe & reliable), but remember it still costs like the $40k car it was to maintain. Learn the basic jobs, like oil & filter, fluids, tire pressure & rotation, maybe even brakes, to save a lot here.
I've been a car engineer for 25 years. Do this and you'll be satisfied.
Oh, and remember: A car can be painted any color for under $500.
Unread 18-10-2011, 22:51
ThaineP
Posts: n/a
Thanks for the advice.
Unread 19-10-2011, 00:00
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Volvo 544
1959 Chevy pickup
1993 Ford Crown Victoria
(these are examples of good first cars from personal experience, they may or may not be good for you)
Unread 19-10-2011, 01:06
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Also consider fuel mileage. More mass = a bigger force to get the same acceleration. Gas can really add up.
Unread 19-10-2011, 01:43
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
VW Jetta
Mini Cooper
I'll assume you want a used car—new is just too expensive. Also, I'll assume this is mainly for commuting, and occasionally for moving in and out of wherever you're living while at school. Those needs aren't particularly special, so you can probably rely on Consumer Reports for ratings.
Accords and Civics are decent cars, but they do get stolen an awful lot (seriously). Is that a consideration? The Jetta and the Mini are probably going to be expensive to maintain.
You might want to consider something like an 8-year-old Protegé (or Protegé 5). A Fit is practical as well, and gets good mileage, but likely more expensive to maintain. If you can deal with ugly, there's always stuff based on the Corolla—they're cheap to buy, operate and maintain.
Unread 19-10-2011, 02:16
Garrett.d.w's Avatar
Garrett.d.w Garrett.d.w is offline
Build Lead
FRC #2733 (The Pigmice)
Garrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to behold
I am actually looking for a first car as well (so I have done a lot of research, it also helps when your dad is a total gearhead). If I have learned anything from my research it is that you should take your time when shopping for a used car, especially if it is no rush. The listings that you find in the classifieds will change quite often, so keep your eye out. You will see a car that you like eventually.
And by the way, I like the idea of the 95 Chevy pickup.
"A mind once stretched by a thought will never regain it's original dimensions."
Optimists think the glass is half full.
Pessimists think the glass is half empty.
Engineers realize it's twice as big as it needs to be.
Unread 19-10-2011, 02:56
Molten's Avatar
Molten Molten is offline
AKA: Jason
FRC #1766 (Temper Metal)
Originally Posted by DonRotolo View Post
...nobody sells a perfectly fine car, regardless of the story.
My number one advice is know what you need. Sometimes a person will sell a perfectly fine car if they are "trading up". My car has no air conditioning and no powered locks or windows. These are things alot of people want in their car, but I'm ok without them. This allowed me to get a car that was otherwise great with low mileage for a fair price. Do you need a cd player? remote starter? powered windows? These are all questions to think about. My car came with a cd player, but it definitely wasn't on my list of needs. It was a bonus.
Jason
"Curiosity. Not good for cats, great for scientists."- Numb3rs
"They can break your cookie, but... you'll always have your fortune."-T.W. Turtle, Cats Don't Dance
"Tell my tale to those who ask. Tell it truly - the ill deeds along with the good, and let me be judged accordingly. The rest... is silence."-Dinobot, Beast Wars
"Though the first step is the hardest and the last step ends the quest, the long steps in between are certainly the best."
–Gruffi Gummi, Disney's Adventures of the Gummi Bears
Unread 19-10-2011, 08:03
JamesCH95's Avatar
JamesCH95 JamesCH95 is online now
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Forget anything German if you're going for low cost of ownership. No BMW, VW, Audi, or Mini (owned by BMW) etc. Some people have great luck with them, many don't.
Crown Victoria's are good first cars (my first car, as it were). I would also consider a Focus.
You're going to pay a premium in the used market for anything with "Honda" stuck to it, but it will probably be a decent car.
Mazda has several good offerings, but I would look at the large used Mazda3 and Mazda6 market.
As don suggested, keep $1k on-hand for repairs. You're saving money in the initial purchase price by going used, but you will spend more money in maintenance and repairs. It's just how cars work. If you're want to go the self-reliance route I would set aside $300-$500 for tools, like a jack, jack-stands, socket set, spark plug tool, oil filter wrench, torque wrenches, etc.
Unread 19-10-2011, 08:16
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Some college kids drive like the biggest nut jobs you'll ever see. Save your first 'nice' car purchase for after college so you're not so focused on someone damaging your nice car; waiting will also make it more satisfying.
DO NOT PURCHASE THE CAR IN THE COLLEGE TOWN. Sorry for yelling. If you buy it from a college kid, it probably won't last another 4 years without a major breakdown sometime (sorry for stereotyping and/or projecting, but I've been there...). College kids aren't known for having enough money to do preventative maintenance on cars. Don's advice is sound -- do the 'small stuff' yourself.
GitHub
Unread 19-10-2011, 09:02
ebarker's Avatar
ebarker ebarker is offline
AKA: Ed Barker
FRC #1311 (Kell Robotics)
ebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond repute
I tend to be a fan of new cars. For going off the college a Honda Civic or Toyota Yaris.
We planned our car buying in our family so that my daughter got a hand-me-down 1999 Accord when she was a HS senior in 2005/2006, drove it through college, still driving it at her new job. The next car she will have she will pay for herself...
That way I'm buying new and I REALLY know the car history....
Reliability, safety, low cost of operation and ownership is what a college student needs.
After school, feel free to blow up your wallet.
Ed Barker
Unread 19-10-2011, 09:11
Andrew Lawrence
Posts: n/a
You could always have the team build you a car. All jokes/things we really want to happen aside, I hear the yaris is good. I am also one of the many fans of new cars, even though I don't have a car yet. IMO, the car with the best technology that's useful to you would help the most.
Unread 19-10-2011, 10:15
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (EarthQuakers)
Avoid Pontiac vehicles if possible, especially mid-90s to mid-00s. I and several of my acquaintances have had major (costly) electrical issues with these cars.
I'll throw in another vote for Ford Escort, Toyota Corolla (or any of its sister cars). Saturn makes a good automobile, but in my experience they fit a certain body type that I just don't have.
Hi!
Unread 19-10-2011, 11:06
MrForbes's Avatar
AKA: Jim
Good advise from Jason. Define the requirements FIRST. It's just like building a robot
I have always been interested in cars, so having an unreliable college car was a great thing, I learned all kinds of neat things about how cars work (and what makes them not work). It helped that my part time jobs during college were car related--first at an auto salvage yard, then at a transmission shop.
I doubt this is how normal people look at buying a car for college, but hey, this is robotics, and we're not normal people.
Unread 19-10-2011, 11:34
The Accords and Civics that get stolen are mid 90's models. More recent ones aren't anywhere near the most stolen list. Only 10% of stolen Accords are from 2000 or later.
