Re: Question about alternate NI cRIO
Cool.
Yea I kinda knew i couldn't use them for the competitions but if i outfitted them with the typical modules of the FRC cRIO, would they be usable as extra robot cRIOs? And for more about doing other things with them, does someone happen to know a great resource for projects to do? Thanks, Davis |
If you have the FPGA tools, they'd make pretty interesting offseason demos, and I think they'd make a pretty awesome offseason field controller.
Greg McKaskle |
Alright,
So now I am having difficulties setting up the cRIO for use for the first time (I have never sucessfully done this before). I am stuck on trying to get the cRIO imaging tool to detect the cRIO. I connected it to my computer (crossover and non), disabled other network adapters, configured ip adress of both correctly (I managed to locate the cRIO under MAX and set the IP adress), tried safe mode, checked on many many threads on this forums, and I attempted to follow 1 MAX manual wich mentioned updating BIOS and ect. Thanks, Davis |
They are not FRC C-RIO's, so the FRC tool will not be able to find it, and you will not be able to image it with the FRC image. You can make your own image with MAX, but that will be very difficult.
The imaging tool filters out controllers that are not compatible. If it showed it, the image wouldn't work anyway. Sorry.
#7
So that means it CAN control a robot, but you need to do all the software stuff the "other" (=non-FRC) way, like a zillion other cRio users in industry.
Not impossible, not all that difficult even, but different for sure. None of the FRC tools or software will be drop-in compatible, But don't let that discourage you one iota, because you have a super resource there for testing and demonstrations and, best of all, learning... |
#8
Ok, well this seems quite over my head (I am good with comuters and due to my schools overhaul, networks too but not no engineer...).
But hey, high school is for learnin, so how might I go about attempting this? Thanks y'all |
