Go to Post After all, bitterness takes all the fun out of wiring. - Venkatesh [more]
Unread 22-10-2011, 18:41
Wendy Holladay's Avatar
Wendy Holladay Wendy Holladay is offline
FRC #1912 (Team Combustion)
Wendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond repute
ftp to crio
I thought I had saved instructions, how to FTP to the crio, but i can't find them. Can anyone give me some help in looking at the files in the crio?
thanks
wendy holladay
Unread 22-10-2011, 19:09
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Re: ftp to crio
Go the windows start menu and then click on "run". Or press the windows key and "R" at the same time.
Type CMD and press enter.
Type FTP 10.XX.XX.2 where XX.XX is your team number and press enter.
There is no default log in and password. Press enter twice.
You're now browsing in the cRio.
If you need to use a windows-gui interface ftp client, simply set it up to ftp to the above address with anonymous login and password.
Unread 24-10-2011, 14:30
~Cory~'s Avatar
~Cory~ ~Cory~ is offline
Student
AKA: Cory Rypkema
FRC #0706
~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold
Re: ftp to crio
To expand:
use the put command to post a file : put file.txt
use the get command to retrieve a file:
use cd to change directory
use dir to list the directory
use ! infront of a command to have it run on your machine (!dir lists your machines files)
Most of the stuff you will be looking for or using is in /ni-rt/
corin.rypkema.org
WPI Class of '17
'12 Dean's List Finalist, Mentor of 706 - Cyberhawks
Unread 24-10-2011, 14:54
Re: ftp to crio
got it working
thanks
