Go to Post ... Imagine NOT being able to count on certain things to stay the same from year to year... It makes you wonder what sort of sick, twisted mind would do such a thing to all those innocent teams out there... - dlavery [more]
Unread 22-10-2011, 13:10
roboticsgoof95's Avatar
roboticsgoof95 roboticsgoof95 is offline
The Giggle-bot
AKA: Jamie Ortiz-DeLeon (giggles)
FRC #4002 (Rhombi Robotics)
Team Role: Operator
roboticsgoof95 has a spectacular aura aboutroboticsgoof95 has a spectacular aura aboutroboticsgoof95 has a spectacular aura about
Question about wheel preferences
My mentors have no interest in mechanum wheels, and i love them. How efficient are they or arent they. I just want outside information about different preferencs on wheels.
______________________________
Jamie Ortiz-DeLeon
eye <3 ^O[]
There is nothing better than finding your one passion and then sharing it with others.<> <> <> <> <> <> <>
Unread 22-10-2011, 13:21
Re: Question about wheel preferences
When you say "efficient" what do you mean by that?
Unread 22-10-2011, 13:23
The Giggle-bot
Team Role: Operator
I just mean like what are the good and bad about these wheels. And what wheels could make up for the bad things about the wheels. if that makes sense
Jamie Ortiz-DeLeon
eye <3 ^O[]
Unread 22-10-2011, 13:28
Not to discourage you from asking, but you might want to try the forum search feature. There have been many many discussions about this. You might be delighted to discover how much you could learn. It's worth the effort.
Unread 22-10-2011, 13:31
The Giggle-bot
Team Role: Operator
alright thanks.
Jamie Ortiz-DeLeon
eye <3 ^O[]
Unread 22-10-2011, 13:44
alright thanks.
This will get you a lot of hits:
1) Go to the forums advanced search page.
2) Set the options as shown here.
Name:	advanced search mecanum.png
Unread 22-10-2011, 15:57
BJC's Avatar
BJC BJC is offline
Simplicity is Complicated!
AKA: Bryan Culver
FRC #0033 (The Killer Bees)
BJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond repute
I'll say two things real quick, then you can go search the topic as much as you'd like:
1. If you like Macanum because they allow superior manuverability to get around defence, then do NOT use them. They are not superior in this regard and are actually MORE suceptable to defence because they can be pushed around so easily. There was a thread on CD a while ago asking for proof of a mecanum driving "circles" around a tank drive. Although there were many videos of the tanks driving circles around mecanums there was not a single video of the opposite.
2. If you like mecanums because they allow you to more quickly allign to field elements this is slightly more valid. However, the lack of traction is still probably an overpowering reason not to use them. Building a simple tank and practicing with it will yield much better results then a mecanum. (Another point: you need lots of practice to be a good mecanum driver.)
Happy searching, Bryan
robot robot robot? Robot. Robot? Robot!
-----------------Team 33------------------
Unread 23-10-2011, 15:08
Marc S.'s Avatar
Marc S. Marc S. is offline
Read the Manual! PLEASE!
AKA: Adversity
FRC #3925 (Robotics)
Marc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond repute
Just a few pros and cons
Pros:
1. Omni-directional movement.
2. Relatively easy to build.
Cons:
1. Usually requires larger heavier wheels(than 6wd's) .
2. Harder to use 2-speed transmission(meaning more load on motors and slower top speeds).
3. Can be easily pushed(with 1 finger).
4. Requires a lot of practice to make effective.
5. Only works for offense.
Alumnus FRC 973: 2010, 2011, 2012, 2013
2011 World Championship Winning Alliance Member
FLL Mentor and Competition Judge 2012-2015
Student-Mentor FRC 5102: 2014, 2015
Student-Mentor FRC 3925: 2015, 2016
FRC Ventura Regional Planning Committee Member & Regional Field Supervisor: 2015, 2016
Unread 23-10-2011, 15:13
Joining the 900 Meme Team
FRC #0079
I'm not a fan of mecanum wheels but I gotta call this one out. Where is your source for this?
Unread 23-10-2011, 15:16
Cons:
I don't think so.
1 finger will not push a 150-lb mecanum drive. Or a 150-lb 4wd. MAYBE a 150-lb omni-drive (with only omni wheels) in the sideways direction can be pushed with one finger.
It's more accurate to say that mecanums have lower pushing resistance and lower pushing power than X drive (where X is some other specific drive type).
Also, I've seen mecanums play effective defense. Effective defense is just as much getting in the way as it is ram and shove someone else around.
Unread 23-10-2011, 15:24
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
It all depends on the game. We used mecanum last year because of the maneuverability and lack of defense in the scoring zone and were quite happy with them. They also aided in easy pick up of tubes. Having said that, the only way we would use them again is if the game had similar rules. The odds are probably 80% we won't use them again.
But common guys lets not over generalize on their faults.
1. Lots of practice needed to be a good driver. Totally not true. They need no more practice than a tank drive.
2. Heavy - wheels are heavier yes but you only need 4 and no chains or sprockets are required so this is also a straw dog.
3. Push with a finger - now your just making things up.
Unread 23-10-2011, 16:06
Marc S.'s Avatar
AKA: Adversity
The reason i say it needs more practice is because, its omni-directional. While it probably doesn't require as much practice as a swerve drive it still has the complexity of one. A 6wd yes does need a lot of practice to make perfect but it is very easy for a new driver to control. I personaly have never driven a mecanum robot so my expirence comes from swerve drives.
Yes they don't need chains or sprockets, but they are still larger and very heavy. The larger diameter the wheel, the more force you need to excelerate regardless. Add weight and the required force goes up even further.
Yes maybe claiming that someone could push a mecanum with a finger was a exaggerated. Frankly I might just be spoiled by robots that can't be pushed at all.
Unread 23-10-2011, 16:23
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
I'd love to see your mythical perfectly stationary robot...
Mentor 2415
Unread 23-10-2011, 16:34
Mecanums aren't larger in diameter than most wheels. They're larger in the axial direction. (Now, if you use 4" wheels, you might think that mecanums are larger, but most teams use 6-8" wheels.)
Unread 23-10-2011, 16:43
BJC's Avatar
BJC BJC is offline
AKA: Bryan Culver
I have to say that I see way too many teams using mecanum drives that are opperating them like a tank drive. Mecanum drives can be effective if they are utilized properly. This requires practice. I know that 2337 does extensive driver training which utilizes a very different mindset then driving a standard tank. They practice stuff like using the opponent's inertia to assist them and peeling off of defenders; a lot of things that are nearly impossible for a tank to do because they REQUIRE the ability to move sideways. So I would say that they require a similar amount of practice for the driver to become proficent (you can never have enough practice) but an entirely different mindset. This is what most teams don't do and a part of the reason why mecanum wheels have a bad name.
