Go to Post Now I want to casually slip the word [B]Hemispherical Omnidirectional Gimbaled Drive[/B] into normal conversation .... - [more]
Unread 24-10-2011, 13:16
whcirobotics's Avatar
whcirobotics whcirobotics is offline
FRC #1514 (Vikings)
whcirobotics is an unknown quantity at this point
How to download java 2011 with all libraries
Hi, team 1514 has been using labview for a couple of years and it has been working good for us but java looks fun and thought i might give it a try .
I was wondering where i can download everything for java including the necessary libraries, like in one package. I did google this, but its confusing :S Any help is appreciated Tnx
Team 1514
"A team back in training !"
Unread 24-10-2011, 18:16
Jared Russell's Avatar
Taking a year (mostly) off
Re: How to download java 2011 with all libraries
This is the link for you: http://firstforge.wpi.edu/sf/docman/...tation/doc1199
Unread 24-10-2011, 18:23
plnyyanks's Avatar
Data wins arguments.
AKA: Phil Lopreiato
You will need the disc supplied in last year's KOP to get libraries and whatnot. Ask some local teams if they have a copy or an image of the disc you can borrow. Or, you can contact FIRST and ask for a replacement disc, or wait until next kickoff (only 74 days 16 hours 41 minutes and 36 seconds, not that I'm counting or anything ). Once you do that, install the updates found here, make sure your cRIO is properly configured to use Java (that's set via the imaging tool), and have at it!
EDIT: that's probably not the most efficient way to do it, but it would work. See above post for the better way
Unread 24-10-2011, 20:21
Sconrad Sconrad is offline
AKA: Connor Young
FRC #0122 (NASA Knights)
Sconrad is an unknown quantity at this point
I am in the same position as the OP, and I got everything I needed from the firstforge site. I haven't yet attempted to deploy the code, so I could be missing something and not realizing it yet. If you already have the driver station and cRIO imaging tool, I'm pretty sure everything else you need is available online (again, not 100% sure, please correct me if I am wrong)
