Go to Post [Goals For 2012] 1. Build on 20 years of hard work. 2. Inspire a new generation so they come back another year. 3. Repeat. - Koko Ed [more]
Unread 07-04-2011, 18:35
Safety3rd Safety3rd is offline
FRC #3140
Safety3rd is an unknown quantity at this point
Dual CIM+CIMple box powered bike
i was contemplating mounting a cim motor onto by 21 speed Fugi mountain bike. i thot that it would be a good idea to mount it at about 8 inches from the peddles and make it chain driven. the chain would run from the small sprocket on the cimple box and around the 1st peddle gear out of three. this would reduce my gear range down to a 14 speed though. im not sure what im going to do about the battery, or powerswitch cus im not planning on having a jaguar or anything, just all or none.
is this a solid idea or design? would it provide good enough torque and speed without slowing down my bike or burning out the motor going up a hill?
Unread 07-04-2011, 20:02
Vermeulen's Avatar
Vermeulen Vermeulen is offline
I have too much free time now
AKA: Tom Vermeulen
FRC #1306 (BadgerB.O.T.S.)
Vermeulen is a name known to allVermeulen is a name known to allVermeulen is a name known to allVermeulen is a name known to allVermeulen is a name known to allVermeulen is a name known to all
Re: Dual CIM+CIMple box powered bike
Just speaking from my minimal experience here, but I would think overheating would be an issue. IIRC, CIMs are designed for light, intermittent duty. Because of that, they have no fans or anything for cooling. This works for FRC matches because they are 2 minutes, 15 seconds long, and the CIM usually doesn't get hot enough to fail by overheating.
Congratulations Ben Senson on winning the 2012 Wisconsin Regional Woodie Flowers Finalist Award!
2012 Wisconsin Regional Semifinalist
2012 Wisconsin Regional Engineering Inspiration Award
2011 Wisconsin Regional Innovation in Control Award
2010 Wisconsin Regional Chairman's Award
2010 Wisconsin Regional Quarterfinalist
2010 Curie Division Quarterfinalist
Unread 07-04-2011, 20:38
FRC #3140
would it be possible to water cool them, by running a pump to circulate cold water over the motors and through a coolant reservoir?
Unread 07-04-2011, 20:44
The torque and speed will depend on your gear ratio. Without knowing a planned gear ratio from the gearbox to the sprocket (and the possible gear ratios from the small sprocket to the larger ones, and from the larger ones to the cluster on the wheel), it'll be hard to answer that question.
An all/none switch may not be the best idea either. If you have a battery that can provide more current than the CIMs can handle, you may find yourself with two fried CIMs. You'll want some form of protection for the motors--a fuse or breaker will work well. If nothing else, a switch with a fuse/breaker in it.
Unread 07-04-2011, 20:45
How many teeth are on the sprocket on the Cimple box output shaft?
How many teeth are on the sprocket on the "1st peddle gear out of three" ?
Unread 07-04-2011, 22:35
Chris is me's Avatar
AKA: Pinecone
You should probably put more thought into this than "I guess putting the CIM onto a random gearbox should work"...
Unread 07-04-2011, 23:17
I think you were responding to post#1 but you linked to post#5.
Unread 08-04-2011, 16:36
FRC #3140
i plan on using the sprocket that comes in the kit of parts ( 12 teeth) and the other gear has 28 teeth
Unread 08-04-2011, 16:48
Now we can do the math:
- The CIM's free speed is 5310 rpm
- The Cimple box steps that down 4.67:1 to 1137 rpm
- Your sprockets step that down 28:12 to 487 rpm
- In order to run the CIM continuous-duty without burning it up, you would want to run it at about maximum efficiency, which is 87.5% of free speed (1/5 horsepower). So 87.5% of 487 is 426 rpm
- 426 rpm is approximately 7 revs/second.
I don't think you normally pedal that fast.
Unread 08-04-2011, 22:32
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
To go all-out with this, look into a NuVinci CVT for bicycles. $400, but pretty cool nonetheless.
GitHub
Unread 25-10-2011, 14:44
hipsterjr's Avatar
hipsterjr hipsterjr is offline
Your bot can score but can it dance
AKA: CJ
FRC #4451 (The Burning Magnetos)
hipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond repute
Send a message via AIM to hipsterjr
Here is the one I built this summer. I think it is the same idea you are shooting for. I just added a clamp-on sprocket to the left of the rear wheel and a freewheel sprocket to the cimbox with 2 cims.
2010 Palmetto Chairmens Winner
2009 Peachtree Finalist Thanks 1319 & 590 "Sure your robot can score, but can it dance?!"
2008 Palmetto Regional Finalist Thanks 343 & 804
2008 Florida Regional Finalist Thanks 179 & 69
2007 Palmetto Regional winners Thanks 1319 & 832
2005 Palmetto Chairmens Winner
Unread 25-10-2011, 15:57
Aren Siekmeier's Avatar
on walkabout
Note that the chain and sprockets in the kit are the #35 spec, with a 3/8" pitch, among other things. Standard bike chain is 1/2" pitch, so you will have to be sure to use a sprocket of that size to fit with everything else on board.
Unread 25-10-2011, 17:05
What is the total gear ratio, from CIM shaft to rear wheel ?
Unread 25-10-2011, 17:18
hipsterjr's Avatar
AKA: CJ
Off the top of my head I can't remember the stock ratio of the 2005 AndyMark gearbox I used (to lazy to look it up), but from the gear box to the wheel is 2.65 : 1. I do remember that I calculated the wheel RPM to be about 140 at the cim motor's peak torque band (geared way down to climb hills that cover Clemson).
Unread 25-10-2011, 17:51
President, AndyMark, Inc.
FRC #3940 (CyberTooth)
That is the FIRST Kit gearbox from 2005, designed by Paul Copioli and sold by IFI. It has an reduction of 12.75:1. So, your overall reduction is 33.8:1. If we multiply this number by your desired max wheel rpm to be 140, then the max motor rpm will be around 4700.
Andy B.
