Go to Post Spouting off without all of the facts is a bad idea. It's also bad to envoke the gods of "Gracious Professionalism" to judge others. - Rich Kressly [more]
Unread 26-10-2011, 00:39
superbotman's Avatar
superbotman superbotman is offline
John
FRC #2169 (KING TeC)
superbotman is an unknown quantity at this point
Run FRC pneumatics with VEX Cortex
I have been taking some of my team's old robots that we removed the C-Rio from and hooked them up to VEX Cortex microcontrollers. Although I was able to get the motors running easily, I am uncertain how to run the pneumatics electrical wiring (if it is possible). The vex pneumatics uses three pins, but the FRC solenoids have only two. Does anyone know how to wire them?
Thanks.
2011-2015 GoFIRST member at U of Minnesota
2009-present Head Referee at MN FTC Snowdrift State Championship
2008-2011 KING TeC (2169) Student member
Unread 26-10-2011, 00:47
Joe G.'s Avatar
Joe G. Joe G. is offline
AKA: Josepher
no team (Formerly 1687, 5400)
Re: Run FRC pneumatics with VEX Cortex
I would suggest using spikes to control your solenoids, just like was done with the old IFI controller. Connect the spike's PWM to a digital output port. For more information on interfacing a spike with the VEX controller, see here.
Hope this helps!
