Go to Post Look, it's only August. You got approximately 6 months to enjoy your life until season starts. Enjoy it while it lasts... - Arefin Bari [more]
Unread 25-10-2011, 22:43
Robopanda6 Robopanda6 is offline
FRC #2477
Robopanda6 is an unknown quantity at this point
Reimaging cRIO w/ Java Technology
We have been trying to reimage our cRIO for the past couple of weeks. We changed the our cRIO about three times. Whenever we have tried reimage we get error 60, so we followed advice on previous forums that tell us ensure that all of our DIP switches our turned off. Now we are getting the error that our cRIO is unreachable and to ensure that our network adapters are on the same subnet.
What should we do?
Help is greatly appreciated.
"They say the struggle only sweetens the success"...I guess that's why I stayed in Robotics.
Unread 25-10-2011, 23:15
kinganu123 kinganu123 is offline
FRC #1747
kinganu123 is on a distinguished road
Re: Reimaging cRIO w/ Java Technology
Make sure you set your IP to DHCP or 192.168.0.xx
subnet 255.255.255.0
and you image using the cRIO imaging tool, which is Labview, not java
Unread 26-10-2011, 00:04
FRC #2477
Thank you for the response.
I know that we use the cRIO imaging tool and I know that it is Labview, i was just specifying the development environment that we are using. I apologize for the misunderstanding.
Unread 27-10-2011, 13:50
Kovs's Avatar
Kovs Kovs is offline
FRC #1259 (Paradigm Shift)
Kovs will become famous soon enough
I have had problems reformatting the cRIO so many times... The thing I forget about the most is that for some laptops (ours), connecting directly to the cRIO doesn't work. We have to connect the laptop to a router and the cRIO to the same router (all using ethernet cable, of course).
(I spent most of a meeting last Monday failing to reformat a cRIO, connecting to it directly, hopefully I'll get it reformatted next Monday)
Unread 27-10-2011, 17:38
FRC #1747
No problem, it happens
Try using a crossfire instead of an ethernet cable. Crossfire cables, as I was told, was meant for two brains to communicate (computer and cRIO)
Unread 28-10-2011, 09:56
JosephC's Avatar
JosephC JosephC is offline
FF: Breakfast Company
AKA: Joseph Cupchack
no team (FiM Volunteer Extraordinaire)
JosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond repute
Do you mean a crossover cable? A crossover cable is used to connect two devices directly together, without needing a modem.
We use to have the same issues while using regular Ethernet cables. Eventually I got upset at the CRIO and bought a crossover cable myself. We don't have anymore problems =D
Referee: 2015 - ?
Field Reset/Supervisor: 2013 - ?
68 Team Member: 2011 - 2013
Unread 28-10-2011, 19:11
FRC #1747
Yes sorry your right, the name I gave was for bridging ATI Graphics cards XD
Crossover is what I meant
