[FTC]: [FTC]: No teleop code
Hey everyone,
We've been trying to run our robot wirelessly through the Samantha FCS and every time we connect we get an error that says our NXT has no teleop code. What should the teleop vi be named in LabView? Also, is there a way to do real-time debugging and data viewing (on front panels) like the crio allows? We are using Labview, and this is our rookie season, so we're trying to figure out how everything's supposed to work. Thanks |
Re: [FTC]: [FTC]: No teleop code
run the autonomous chooser program from the try me files on the nxt, and pick your teleop program, then press start match on the fcs and it should work
