Go to Post A lack of knowledge is okay; a lack of initiative to learn more is not. - Madison [more]
Unread 29-10-2011, 09:01
Spirator Spirator is offline
AKA: Munaum Muhammad
Spirator is a jewel in the roughSpirator is a jewel in the roughSpirator is a jewel in the rough
High Tensile Sprocket Bolts
Hello, in our rookie season, Breakaway, our robot managed to shear the drive sprocket off the centre wheel. We were using the standard Andymark #10-32 bolts on an 8" Plaction wheel and it was being driven off an Andymark Toughbox with 2 CIM motors.
We're concerned because we want to make sure that a 6WD Plaction set up isn't going to have a repeat and we concerned to the point of buying hi-tensile bolts as replacements.
Out of your own experience and knowledge, what do you think would cause such a break? The bolts holding the sprocket onto the wheel broke, if I recall correctly.
