Go to Post Feelings are like the laws of physics: if some one feels offended or alienated, then they are offended or alienated - it doesnt matter why you dropped a hammer, if it falls on someones head they will be hurt. You cant expect it to not hurt, because you did not intend to hurt them. - KenWittlief [more]
Unread 29-10-2011, 09:01
Spirator Spirator is offline
AKA: Munaum Muhammad
Spirator is a jewel in the roughSpirator is a jewel in the roughSpirator is a jewel in the rough
High Tensile Sprocket Bolts
Hello, in our rookie season, Breakaway, our robot managed to shear the drive sprocket off the centre wheel. We were using the standard Andymark #10-32 bolts on an 8" Plaction wheel and it was being driven off an Andymark Toughbox with 2 CIM motors.
We're concerned because we want to make sure that a 6WD Plaction set up isn't going to have a repeat and we concerned to the point of buying hi-tensile bolts as replacements.
Out of your own experience and knowledge, what do you think would cause such a break? The bolts holding the sprocket onto the wheel broke, if I recall correctly.
Unread 29-10-2011, 09:17
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Re: High Tensile Sprocket Bolts
We've bent quite a few #10's in the same spot over the years. What I've found is that in a perfect world, the sprockets should be bolted directly to the wheel, not spaced out at all. I've seen quite a few teams run into issues when spacing beyond about 1/4" or so.
Did you space your sprockets away from the wheel at all?
On the subject of bolts, we've usually been able to get away with common alloy steel bolts from McMaster Similar to part number 91251A353. They're made from a steel that's arguably the same as Grade 8 and hold up really well. In 2008, we used fully threaded Grade 5 10-32's from home depot that sheared between the threads at one of our off seasons - so now we try to stay away from fully threaded bolts.
-Dustin Benedict
Unread 29-10-2011, 09:25
Chris is me's Avatar
AKA: Pinecone
You'll want graded bolts.
I'd imagine that having a partial thread would be stronger than a full thread. I don't think the sprocket was spaced off the wheel at all.
Could it have been due to poor alignment or loose connections in other places or is it due to the amount of torque we were placing on the centre wheel?
Unread 29-10-2011, 09:39
DonRotolo's Avatar
Back to humble
FRC #0832
You need greater shear strength, not tensile strength.
It is possible that the fasteners were not as tight as they should have been. Loose fasteners in this application puts a lot of shear force on the fastener. Make sure they are torqued properly and use self-locking fasteners.
The goal is to use the clamping force of the fastener to create enough friction between the joined pieces to that the fastener is only in tension and not in shear.
Increasing the hardware size can help, but you can even shear 1/4-20 bolts if they're loose.
Unread 29-10-2011, 09:47
thefro526's Avatar
Mentor for Hire.
Yes, a partial thread should stronger than a full thread in Shear (Depends on a few other factors, but usually it's always stronger). If the sprocket wasn't spaced off of the wheel at all, then you might be running into some other issues.
If the bolts holding the sprockets to the wheel weren't tight, it could cause some issues, especially if the sprocket was allowed to move under load. Poor Alignment could also cause the bolts to see more load then they should, but how much would depend on how bad everything is.
-Dustin Benedict
Unread 29-10-2011, 10:14
kramarczyk's Avatar
kramarczyk kramarczyk is offline
is getting his kicks.
AKA: Mark Kramarczyk
FRC #3096 (Highlanders)
kramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond repute
Most bolted joints use the tension on the bolt to clamp the pieces together. Friction then prevents movement of the joint. Fasteners that are not tightened adequately will fail prematurely as the joint is allowed to move. This puts the bolt in shear where it will fail a ~0.6-0.5 of it's tensile strength. In the case of a sprocket on a wheel, not only does the loose joint have half it's strength, but the sprocket can get a small running start before contacting the bolts. This increases the load being generated.
Socket Head Cap Screws, SHCS, are actually stronger than grade 8 bolts of the same diameter. Grade 8 bolts have a Ultimate Tensile Strength (UTS) of 150 ksi* and proof strength of 120 ksi per SAE J429. SHCS have a UTS of 180 ksi and proof strength of 140 ksi per ASTM A574. This makes SHCS 20% stronger based upon the UTS. SHCS are also harder than grade 8 fasteners.
You can find this information and a lot more about bolted joints in the Unbrako Engineering Guide at http://www.unbrako.com/docs/engguide.pdf. The figures quoted above are from page 71 of this guide.
*1 ksi = 1000 psi
Mark
Brick walls are for other people. - Randy Pausch
Unread 29-10-2011, 11:37
daniel_dsouza daniel_dsouza is offline
does what needs to be done.
FRC #2449 (Out of Orbit Robotics)
daniel_dsouza has a spectacular aura aboutdaniel_dsouza has a spectacular aura about
I can attest to that. We were using the 2011 kit bot for a demonstration at a school, but found that the robot was not driving correctly (complaining loudly when turning). Guess what we found when we checked our wheels (which had no spacing between the sprockets and wheels). Every single bolt was loose (resulting in alignment issues which caused the chain to make noise), and the treads had been destroyed.
Unread 29-10-2011, 13:22
AdamHeard's Avatar
Lead Mentor
I've seen a lot of teams bolt on sprockets with nothing aligning the sprocket to the shaft (except for the bolts). If there is something (bearing works great), aligning it to the shaft it will greatly reduce the likelihood of the bolts failing.
Unread 29-10-2011, 13:39
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
We've gone so far as using 3 10-32's per wheel and never broken or bent a bolt. I'd look into the set up and take into consideration what Adam said. Use something else like a hub to handle the forces.
Mentor 2415
Unread 29-10-2011, 13:42
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Agreed,
This helps quite a bit, we used to wonder why we would shear bolts as well... Until we figured out that a bearing or some sort of a bushing works wonders!
-RC
R.C.
MadTown Robotics Team 1323
Unread 29-10-2011, 15:54
Gdeaver Gdeaver is online now
FRC #1640
This is our plactraction wheel set up for dead axle. May help.
Unread 29-10-2011, 18:15
Trent B Trent B is offline
College Mentor
AKA: Trent Borman
no team (Surviving Grad School)
Trent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to behold
Send a message via AIM to Trent B Send a message via Yahoo to Trent B
As Don said you want bolts with a higher shear force rather than tensile force, and partially threaded is better than fully threaded. From a partially threaded standpoint you want as few threads between the bolt head and the nut as possible (eg get as few as possible to have a tight fit) because each thread acts as a crack and the stress from shear force will concentrate their increasing the odds of failure.
Additionally make sure the change in stress as the wheel rotates is at the minimum for each bolt (eg center the sprocket well, evenly tightened bolts etc.) Fatigue or failure as a result of changing stress amplitude through a cycled application is one of the leading causes of failure in parts.
Former 2502 (Talon) Captain and 3928 (Neutrino) Mentor, currently teamless and attending Penn State for graduate school.
Have questions about Iowa State University or Penn State University? Feel free to email or PM me
Unread 29-10-2011, 18:24
AdamHeard's Avatar
Lead Mentor
Seems like 91920A280 would be a better choice for those standoffs. Keeps the same functionality, but replaces the fastener that holds the sprocket on with a bolt rather than a nut; It would be much more convenient, also a good deal cheaper.
Unread 29-10-2011, 18:30
College Mentor
AKA: Trent Borman
Adam did you mean sprocket instead of wheel on?
Also I agree that the other option may be a better choice, as the sharp angle at the base of those standoffs is another stress concentration area that would prove to be a weak spot and prone to failure.
