Go to Post The urge to compete tends to drive teams to hold the ideas close during the competition season, but the urge to contribute means they get publicized afterwards. - Alan Anderson [more]
Unread 29-10-2011, 18:24
AdamHeard's Avatar
Lead Mentor
Re: High Tensile Sprocket Bolts
Originally Posted by Gdeaver View Post
This is our plactraction wheel set up for dead axle. May help.
Seems like 91920A280 would be a better choice for those standoffs. Keeps the same functionality, but replaces the fastener that holds the sprocket on with a bolt rather than a nut; It would be much more convenient, also a good deal cheaper.
Unread 29-10-2011, 18:30
Trent B Trent B is offline
College Mentor
AKA: Trent Borman
no team (Surviving Grad School)
Trent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to behold
Send a message via AIM to Trent B Send a message via Yahoo to Trent B
Adam did you mean sprocket instead of wheel on?
Also I agree that the other option may be a better choice, as the sharp angle at the base of those standoffs is another stress concentration area that would prove to be a weak spot and prone to failure.
Former 2502 (Talon) Captain and 3928 (Neutrino) Mentor, currently teamless and attending Penn State for graduate school.
Have questions about Iowa State University or Penn State University? Feel free to email or PM me
Unread 29-10-2011, 19:12
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Fun times. Our 2010 soccer bot was 8 wheel drive. The AM sprockets were small enough that we had to use spacers for the chain to clear the wheel hub.
We have sheared off close to 50 bolts. Grade 8, partial thread. We know they are tight, because we were tightening them so MUCH that we started bending the sprockets and compressing the plastic of the plaction wheel.
Simply put, the combination of AM sprockets, with AM spacers, on AM plaction wheels, can't hold up over time. The 10-32 bolts will sheer every time if you're putting serious loading on them. This is on a 4 inch wheel with 24(ish) teeth on the sprocket. 2 cims per side, run through tough boxes. A 3:2 sprocket ratio from the tough box to wheels.
AM could address this by putting locking indentations on both the plaction and the sprocket, and then putting bumps on the spacer so that when the three are clamped together, the bumps/buttons take the shear.
Bolts stink in shear. Tension is their game.
This year, we went with bigger sprockets so that we could get rid of the AM spacers. We never sheared a single bolt. Lesson learned.
Unread 29-10-2011, 19:31
Chris is me's Avatar
AKA: Pinecone
We just used it as an excuse to switch to live axle. Works well so far.
Unread 29-10-2011, 19:34
AdamHeard's Avatar
Lead Mentor
Spacing off the sprocket will increase the likelihood of breaking bolts. We've never sheared 3 bolt patterns of the same diameter in situations with higher loading, but the sprocket was aligned to the shaft and there was no gap between the items being fastened.
For teams that keep failing the full 6 bolt pattern, have you tried replacing 2-4 bolts with shear pins?
A while ago I noticed the holes in Am's sprockets are .206", which is a bit big for a #10. This slop (and not accounting for it by aligning the sprocket on the shaft) is further weakening the interface.
Unread 29-10-2011, 20:01
College Mentor
AKA: Trent Borman
Inherently by using spaces you are cantilevering the bolts which extends the amount of shear stress it is feeling. I would go with adams earlier part suggestion of a hex shaped nut that can screw onto the bolt in fit in the placation wheel holes, thus the bolts will be rigidly held relative to the wheel hub and have extra support (via the nut) for the period they extend beyond the surface of the plaction wheel.
Shearing is greatly related to the amplitude of stress, if you can see concentric semi circles that all seem to be surrounding one point on an edge of the sheared face and expanding as they cross the face it was likely fatigue failure.
Steel bolts, if below their fatigue limit should never fail due to fatigue, if you notice a fatigue pattern (you can find pictures online) you need to reduce the load you are putting on the bolts through some means.
