Go to Post FIRST is not all about the competitions. FIRST is about what you learn to get to wherever you got to, whether that be first seed or last. - StephLee [more]
Unread 29-10-2011, 19:12
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Re: High Tensile Sprocket Bolts
Fun times. Our 2010 soccer bot was 8 wheel drive. The AM sprockets were small enough that we had to use spacers for the chain to clear the wheel hub.
We have sheared off close to 50 bolts. Grade 8, partial thread. We know they are tight, because we were tightening them so MUCH that we started bending the sprockets and compressing the plastic of the plaction wheel.
Simply put, the combination of AM sprockets, with AM spacers, on AM plaction wheels, can't hold up over time. The 10-32 bolts will sheer every time if you're putting serious loading on them. This is on a 4 inch wheel with 24(ish) teeth on the sprocket. 2 cims per side, run through tough boxes. A 3:2 sprocket ratio from the tough box to wheels.
AM could address this by putting locking indentations on both the plaction and the sprocket, and then putting bumps on the spacer so that when the three are clamped together, the bumps/buttons take the shear.
Bolts stink in shear. Tension is their game.
This year, we went with bigger sprockets so that we could get rid of the AM spacers. We never sheared a single bolt. Lesson learned.
Unread 29-10-2011, 19:31
Chris is me's Avatar
AKA: Pinecone
We just used it as an excuse to switch to live axle. Works well so far.
Unread 29-10-2011, 19:34
AdamHeard's Avatar
Lead Mentor
Spacing off the sprocket will increase the likelihood of breaking bolts. We've never sheared 3 bolt patterns of the same diameter in situations with higher loading, but the sprocket was aligned to the shaft and there was no gap between the items being fastened.
For teams that keep failing the full 6 bolt pattern, have you tried replacing 2-4 bolts with shear pins?
A while ago I noticed the holes in Am's sprockets are .206", which is a bit big for a #10. This slop (and not accounting for it by aligning the sprocket on the shaft) is further weakening the interface.
Unread 29-10-2011, 20:01
Trent B Trent B is offline
College Mentor
AKA: Trent Borman
no team (Surviving Grad School)
Trent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to behold
Send a message via AIM to Trent B Send a message via Yahoo to Trent B
Inherently by using spaces you are cantilevering the bolts which extends the amount of shear stress it is feeling. I would go with adams earlier part suggestion of a hex shaped nut that can screw onto the bolt in fit in the placation wheel holes, thus the bolts will be rigidly held relative to the wheel hub and have extra support (via the nut) for the period they extend beyond the surface of the plaction wheel.
Shearing is greatly related to the amplitude of stress, if you can see concentric semi circles that all seem to be surrounding one point on an edge of the sheared face and expanding as they cross the face it was likely fatigue failure.
Steel bolts, if below their fatigue limit should never fail due to fatigue, if you notice a fatigue pattern (you can find pictures online) you need to reduce the load you are putting on the bolts through some means.
Former 2502 (Talon) Captain and 3928 (Neutrino) Mentor, currently teamless and attending Penn State for graduate school.
Have questions about Iowa State University or Penn State University? Feel free to email or PM me
Unread 29-10-2011, 20:25
DonRotolo's Avatar
Back to humble
FRC #0832
If you are using spacers to offset the sprocket, the larger the outside diameter of the spacer the more it will resist bending (and thus shear on the fastener) forces. The hex spacer is not better if it is the same effective diameter as a round spacer. The 'ideal' (for strength) would be a complete ring with holes drilled for the fasteners.
Adding some kind of surface feature as Tom Line mentioned would further put the stresses onto components that can handle it (i.e., not fasteners) because, as Tom also mentioned, #10 hardware is far better in tension than shear.
Unread 29-10-2011, 21:18
Like this? http://www.andymark.com/product-p/am-0207.htm
Unread 29-10-2011, 21:39
College Mentor
AKA: Trent Borman
Wouldn't the hex holes in the plaction wheel help absorb some of the shear force over a circular spacer that was barely unable to fit in the hex holes?
Unread 30-10-2011, 04:37
Spirator Spirator is offline
AKA: Munaum Muhammad
Spirator is a jewel in the roughSpirator is a jewel in the roughSpirator is a jewel in the rough
Thanks for the advice guys! We're thinking of ordering some SHCS from AM pre season for our protobot. Hopefully they won't shear and if they do, we'll have an odd 40 lying around as replacements.
Unread 30-10-2011, 13:44
DonRotolo's Avatar
Back to humble
FRC #0832
Not really. Technically yes if the tips of the hex extended further from the centerline of the fastener than a round spacer (which wouldn't extend to the 'points'), but that would be very little help.
It has to do with lever arms and resistance to bending. A very thin spacer would be able to more easily move/tilt due to the torque of the wheel (that is, in the shear direction). A wide spacer (or the neat device Joe Ross linked to - thanks Joe!) wouldn't tilt as much (or at all).
Shear over a wide area is bending. Think of a bolt sticking out an inch, force on the end of that bolt will bend the bolt. Apply that same force at 1/16" from the supporting structure and it won't bend as much. That's why someone said that adding spacers to put the sprocket further out from the wheel makes things worse.
Unread 30-10-2011, 13:56
College Mentor
AKA: Trent Borman
I guess where my confusion lies is if you have a physically longer spacer (eg one that goes into the holes on the wheel as well) would that offset some of the shear force and thus make the bolt more resistant to bending than it would be with a short spacer?
Unread 30-10-2011, 21:05
George C's Avatar
George C George C is offline
AKA: George Chisholm
FRC #1360 (Orbit Robotics)
George C is a splendid one to beholdGeorge C is a splendid one to beholdGeorge C is a splendid one to beholdGeorge C is a splendid one to beholdGeorge C is a splendid one to beholdGeorge C is a splendid one to beholdGeorge C is a splendid one to behold
If you're having that much trouble with 10-32 bolts shearing off, why not just drill out the holes and use a #12-24 NC or 1/4-28 NF? McMaster Carr doesn't seem to carry #12-28 NF but other suppliers might.
Unread 30-10-2011, 22:07
Tom Line's Avatar
I can't speak for other teams, but we don't drill out the plactions and sprockets because we reuse them each year. We don't have a tremendously huge budget, so we'd rather spend the $25 a year replacing the fasteners rather than the $150-$200 buying new plaction wheels and sprockets to meet the letter of the FIRST rule.
Unread 31-10-2011, 09:53
Brandon Holley's Avatar
Tom-
Can you just clarify what setup you had on your plactions. Was it a full combination of AM plactions, AM (plastic) spacers, and AM sprockets?
Was there generally a period of time before you would shear the bolts? For example, would you replace the bolts, get ~20 matches out of them, and then end up having to replace those bolts again?
I'm just hypothesizing about the nature of plastic parts in these situations. I'm wondering if the plastic parts creep slightly and therefore gradually lose the pre-load of the bolt. The parts may still appear tightly attached together, but losing some of that pre-load would then amplify any shear stress on the bolt and eventually cause a failure.
Just a thought I had.
-Brando
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
Unread 31-10-2011, 16:05
Tom Line's Avatar
Originally Posted by Brandon Holley View Post
Tom-
-Brando
We started seeing bolts shear about midway through our second district. We played through the semis of the first district, so that was 20-24 matches, + about half of the next competition - 10 or so. So call it 32 matches.
What we routinely see is that the locknut shears off, then the bolt head works its way out until it starts hitting the frame. It's always the nut side of the bolt that shears (probably due to the smaller minor diameter where the bolt is threaded).
The components are mostly Andy Mark. The plaction and sprocket is AM, the spacer is a copy of their design made out of ABS, so it's solid rather than having the pockets theirs has.
After the first failures, we put new hardware in and over-tightened them - the chain actually started skipping teeth because we bent the sprockets they were so tight. After that we taught the kids to tighten them but stop if they saw any deflection - essentially as 'tight' as they could be without causing damage.
We ran the same gear ratio in '11 but with no spacers and never had to replace one bit of the hardware. Perhaps the plastic to plastic interface is too slippery and allows relative motion.
Unread 31-10-2011, 16:13
AKA: Pinecone
If the plastic was failing, a longer spacer would distribute the load across more of the plastic, but in this case the bolt is failing and that's a stress concentration problem... if I'm anywhere near approaching an understanding of what people are talking about.
