Go to Post Keep in mind that the lady Amanda has just taken a new job, moved herself to the NorthEast, and has to put up with people like Grady, Needel, the Kelsos, and Boucher. Let's give her some patience and sympathy. - Andy Baker [more]
Go Back   Chief Delphi > Technical > Electrical > CAN
Unread 30-10-2011, 19:46
rudun's Avatar
rudun rudun is offline
FRC #0496 (Royals)
rudun is an unknown quantity at this point
Null motor error
We have gotten the black jaguar serial bridge set up. The jaguars have the latest firmware, we have flashed the crio with v92. I am able to spin a motor with BDC-Comm. However when the robot initializes it throws a null motor exception. we are using java and just using a try like this.
try { leftMotor = new CanJaguar(2); }
catch (Exception e) {
System.out.println(getMessage());
Unread 31-10-2011, 08:49
Re: Null motor error
Originally Posted by rudun View Post
...when the robot initializes it throws a null motor exception.
From a quick look at the Java framework, it seems that the "Null motor provided" exception comes from the RobotDrive constructor. Check to make sure it's getting called with all necessary parameters.
Unread 02-11-2011, 18:52
rrossbach rrossbach is offline
AKA: Ron R
FRC #2607 (RoboVikings)
rrossbach is a splendid one to beholdrrossbach is a splendid one to beholdrrossbach is a splendid one to beholdrrossbach is a splendid one to beholdrrossbach is a splendid one to beholdrrossbach is a splendid one to beholdrrossbach is a splendid one to behold
The class is CANJaguar, not CanJaguar.
- Ron
FIRST Mid-Atlantic Volunteer
FRC Team #2607 Mentor
Unread 03-11-2011, 10:17
rudun's Avatar
FRC #0496 (Royals)
It turned out that it was a problem with the terminator. It was working with the bdc-comm utility, but was taking too long to return a signal to operate with the crio. After replacement we got it to work.
In response to the previous post it was a typo on the post, not the code. Otherwise we would not have been able to tell you what it was returning or been able to compile the code.
Thanks for the responses.
