Go to Post FIRST is kind of like charity work... you are, even if only in some small way, helping our future just a little bit, and you get a great feeling from it. Even if you are just ringing a bell (or clapping MOE sticks together), you're helping. - Amanda Morrison [more]
Unread 31-10-2011, 20:59
FRC #1836 (MilkenKnights)
Sheet Metal
Recently I have been researching sheet metal. Obviously it makes many more designs viable, than just 8020. Our team doesn't have the ability to machine/manufacture a full sheet metal robot, but as leader of our CAD team, I hope to use a hybrid solution of square tube and sheet metal on our 2012 robot. I had a few questions to other teams, preferably ones that have used a design like the one I hope to use, or have done full sheet metal designs:
What would be the possible advantages and disadvantages of doing this?
What thickness would you recommend?(In general, but also for my specific idea)
Thank you so much.
Unread 31-10-2011, 21:04
Billfred's Avatar
Billfred Billfred is offline
Re: Sheet Metal
2815 did this in a way in 2011--we used flat aluminum riveted to square tubing acquired from Lowe's. We had plenty of other issues, but nothing with that frame. I could easily see a team pursuing this strategy if the limits of their equipment meant smaller pieces were an option.
Unread 31-10-2011, 21:55
James Tonthat James Tonthat is offline
FRC #0148 (Robowranglers)
James Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond repute
Re: Sheet Metal
Hybrid is the way to go. I like looking at 228 as one of the really good examples of hybrid sheet/tube done well.
http://team228.org/media/pictures/
As thickness goes, 0.125" will generally do all your fixturing/bracketing needs.
What resources do you have? Also, have you thought of bringing in sponsoring resources?
James Tonthat
Mechanical Engineer, RackSolutions, a subsidiary of Innovation First International
Lead Engineer - Texas Torque - 2009-2014
Mentor - Robowranglers - 2015-
Unread 31-10-2011, 23:06
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Sheet Metal
If you have the design know-how and a sponsor with a laser cutter and press brake, then by all means, sheet metal is an awesome way to go. However, it does take someone who is skilled in sheet metal design to come up with all the proper bends and flanges to get it all to come out strong.
Unread 31-10-2011, 23:58
Re: Sheet Metal
Sorry that I was not clear. We are trying to secure sponsors, but this is our first year that our team is really taking off. We really only have a drill press and mill available to us. In leu of that, I was talking about doing something more like what Billfred suggested. Is it worth it to use sheet metal, even with our limited resources, and inability to make flanges.
Unread 01-11-2011, 01:37
Re: Sheet Metal
Here's one way to do sheet metal without a brake. http://2008.huntingtonrobotics.org/t...monocoque.html
Unread 01-11-2011, 08:08
Re: Sheet Metal
Thank you so much everybody. After doing more research, I have found what I want to do is build a full chassis out of square tube, connected with gussets and rivets, and with a supplement of sheet metal for it's cleaner, more adaptable uses. Has any other team done something like this?
Unread 01-11-2011, 08:33
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Re: Sheet Metal
This actually isn't all that uncommon and is a perfectly fine way to build a chassis. 571 has built frames using this method before: http://www.chiefdelphi.com/media/img...9efd2731_m.jpg
-Dustin Benedict
Unread 01-11-2011, 09:35
jwfoss jwfoss is offline
Chasing Elegant Simplicity
AKA: Justin Foss
Re: Sheet Metal
A hybrid design is an excellent option, you will notice that most teams who build with sheetmetal still use "traditional" round or square tube parts. One idea that you might want to look into is the idea of nesting your drivetrain inside of a larger extruded aluminum tube. This can be seen on teams 177, 816, as well as the "Rock Box" from the 221 Robotics guys.
Other options include designing with standard C-Channel.
1/8" material thickness is common for sheetmetal and a relatively safe bet, some teams use thinner as well such as 0.090". In terms of alloys: Aluminum 5052 is great for bending and is what most of the teams that use sheetmetal use. For extrustions or flat plates/gussets 6061 is common and fine.
Again with all designs, always design within you teams capabilities... Expand your resources and then expand your design.
Unread 01-11-2011, 12:54
Ashley Painter's Avatar
Ashley Painter Ashley Painter is offline
FRC #3784 (Bit by Bit)
Ashley Painter is an unknown quantity at this point
Re: Sheet Metal
Our robot has several sheet aluminum covers/guards on it. I bent up several of them in an evening with a vise, hammer, and sheet metal brake. Aluminum is nice if you have few tools becuase it can be bent by hand somewhat. If you're going to use fasteners aluminum is good but for welding, iron is so much easer.
FRC Team 3784
2011 Highest Seeded Rookie
2011 Gracious Professionalism
2011 Kansas City Champions
2011 ISEF Finalist
FRC Team 3784
2012 Kansas City Champions
Unread 01-11-2011, 12:57
MattC9's Avatar
MattC9 MattC9 is offline
MattC9 has a spectacular aura aboutMattC9 has a spectacular aura aboutMattC9 has a spectacular aura about
Re: Sheet Metal
Here's a nice tip that I have found out, .125 does not like to bend .090 likes to bend. So if you are planning to bend go .090 but if not go .125. We have a break and it did not like the 1/8th inch alum. we tried to bend the other day, it bent but not very well the .090 bends very well from what we have seen.
Unread 01-11-2011, 13:21
AdamHeard's Avatar
Lead Mentor
Re: Sheet Metal
This will vary heavily based on the alloy.
