Go to Post Not sure if its fair to call this or not yet. Back a group of dedicated teenagers far enough into a corner, and they're gonna find a way out. - Racer26 [more]
Unread 31-10-2011, 23:27
Trent B Trent B is offline
College Mentor
AKA: Trent Borman
no team (Surviving Grad School)
Trent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to behold
Send a message via AIM to Trent B Send a message via Yahoo to Trent B
Re: California Drive
A live axle has the axle rotating and used to drive the wheel. A dead axle is where any rotation of the axle is inadvertent; it's your standard chain-sprocket-wheel setup.
To elaborate.
Live axle is where the axle is suspended in bearings and the sprocket and wheel are rigidly attached to it (direct drive is also a live axle design using the gearbox shaft as an axle)
Dead axle is where the axle is any rod (in some cases just a standard bolt from a hardware store) and the wheel is on bearings with a sprocket bolted to it.
Another note, 6WD is often much better than 4WD especially in a drop center configuration because it takes an incredible amount of torque to rotate a 4WD system due to the long wheel base, whereas 6WD with a drop center configuration has an effectively shorter wheelbase.
Former 2502 (Talon) Captain and 3928 (Neutrino) Mentor, currently teamless and attending Penn State for graduate school.
Have questions about Iowa State University or Penn State University? Feel free to email or PM me
