Go to Post Whatever you do, do it in graciously professional manner. - EricH [more]
Unread 04-11-2011, 13:58
Fe_Will's Avatar
Fe_Will Fe_Will is offline
AKA: Will
FRC #0955 (CV Robotics)
Fe_Will has much to be proud ofFe_Will has much to be proud ofFe_Will has much to be proud ofFe_Will has much to be proud ofFe_Will has much to be proud ofFe_Will has much to be proud ofFe_Will has much to be proud ofFe_Will has much to be proud ofFe_Will has much to be proud of
Re: Pressure sensor trouble
Make sure you are wiring the 5V and signal wires correctly. If you send 5V down the signal input on the side car it will overheat the side car board. This can cause the resin on the board to become a liquid and start to flow. It can even become hot enough to desolder the connections. Depending on the duration and extent of damage the side car can sometimes be repaired. Most of the time it is permanent.
"It is the mark of an educated mind to be able to entertain a thought without accepting it." -Aristotle
