Go to Post I must caution against using my sense of humor as any sort of litmus test for good taste. - dlavery [more]
Unread 04-11-2011, 21:08
kinganu123 kinganu123 is offline
FRC #1747
kinganu123 is on a distinguished road
Robot loosing communication when switching directions
We've been fixing up last years robot and discovered a strange issue with our motors. Whenever we suddenly switch directions on our motors (i.e. full positive to full negative or switching rotation directions), our robot suddenly loses all communication with our classmate and the robot stops moving. The wires are still secure so it cannot be those getting loose. Anyone have any ideas on what the problem could be and any possible solutions? Thanks
Unread 04-11-2011, 21:19
James Tonthat James Tonthat is offline
FRC #0148 (Robowranglers)
James Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond repute
Re: Robot loosing communication when switching directions
We had this issue when we had plugged the radio power converter into a regular 12v 20Amp instead of the protected 12v that's dedicate to the radio.
James Tonthat
Mechanical Engineer, RackSolutions
Texas Torque - 2009-2014
Robowranglers - 2015-
Unread 04-11-2011, 21:54
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
All we know at this point is that you're losing communication.
This could be due to a physical problem like loose ethernet connections or power connections. It could also be an electrical problem like low battery voltage (or plugged in to the wrong port). You are using the transformer, correct?
Unread 04-11-2011, 23:17
dudefise dudefise is offline
FRC #2637 (Panthers)
dudefise is an unknown quantity at this point
It's a problem with power distibution.The load spike caused by reversing the motors is causing the cRio or radio to lose power... use the protected 12 and 24 volt boost supplies on the bottom of the PD board.
2010 VRC 2453B - Team Captain
2011 FRC 2637 - Electrical - Las Vegas Regional Semifinalists with 1726 and 166
2012 FRC 2637 - Electronics Captain - Las Vegas Regional Semifinalists with 1661 and 2984
2013 FRC 2637 - Build Captain - Inland Empire Quarterfinalists with 3925 and 207
2014 FRC 2637 - College Mentor - Central Valley Quarterfinalists with 2085 and 5136 / LA Regional Semifinalists with 696 and 5102
2015 FRC 2637 - Lazy Schmuck - Couch Sitting Quarterfinalist
2016 FRC 2637 - College Mentor - SD Regional Finalist with 1572 and 2443, Excellence in Engineering, Wildcard
Unread 05-11-2011, 21:51
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
A little more unlikely explanation, but still worth considering, is that when you reverse the directions, you are causing a spike (literally a spark jumping a gap) inside the motor which can mess with you Wi-Fi signals. You can sometimes see this with the Fisher-Price and other unsealed motors. It's unlikely, but it's still worth considering. Does the Wi-Fi re-lock after some time?
Unread 05-11-2011, 22:09
This is exactly the result when the Crio chassis is electrically connected to the frame and a motor or other wiring also is connected with the frame. Typical of certain Banebots motors shipped after the beginning of build in 2011, was a case short. Even if you were sure you had adequate insulation under the Crio, check it again with a meter. When you reverse motors under this condition, the power going to the Crio is cut in half by the short. The result is a Crio reboot.
Unread 06-11-2011, 09:34
Mr. Lim Mr. Lim is offline
AKA: Mr. Lim
I second both James' and Al's suggestions, and have some tips to offer to help troubleshoot:
1) Al's suggestion: If it IS a cRIO reboot, you'll lose comm for about 1 minute, then it will come back. The time duration of your comm loss is a good indicator here. If you are running any Banebot 775s on your robot this is likely your problem, and you can check by taking a meter, disconnecting the motor from the speed controller, and measuring resistance between the positive terminal on the motor and the case of the motor. You will want to rotate the motor slightly as your measure. If at any point you see <100k ohm resistance, you have a defective motor which is causing the voltage to dip on your entire electrical bus. There are a few fixes for this that have been posted on CD. Try searching for "case short".
2) James' suggestion: As soon as you lose comm, have two people immediately check the status lights on robot. One person for the cRIO, the other for the radio. Both have telltale blinking-light sequences which are indicative that they've been reset recently. If only the radio looks like it's been reset, then James' suggestion is your best bet. Generally with radio-only resets, comm is re-established faster than 1 minute.
In life, what you give, you keep. What you fail to give, you lose forever...
Unread 06-11-2011, 11:57
Phalanx's Avatar
Phalanx Phalanx is offline
Formerly Team 1089 (Mercury)
AKA: Michael Reffler
FRC #5431 (Titan Robotics)
Phalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond repute
I was working with / trying to help these guys yesterday at Brunswick Eruption. There were numerous problems being identified and we were trouble shooting them one at a time. This is as far as were able to get.
1) The ground wasn't firmly attached to the stud on the PD. Fixed
2) One Gear Box was loose and wobbling. Fixed
3) We measured the power drop between the studs on the PD with a multi-meter when they changed directions it went from 12volts to 8volts and lower.
We recommended fully charged batteries.
4) I didn't check if the CRIO rebooted, but the DLINK rebooted every time.
5) They also have the D-Link powered by a 20AMP circuit like James posted previously.
6) Lastly, I'm wondering if direct driving Mechanum Wheels using 4 - CIMPLE Boxes wasn't enough of a mechanical reduction and hence cause too much draw.
Don't just ask the experts, become one!
Leadership is not about ability. It's about responsibility!
Diagonally Parked in a Parallel Universe. It's okay we do Quantum Physics
Unread 06-11-2011, 12:58
Fixing that should take care of the communication dropout immediately. Then they can start working on the other electrical issues (battery charge/condition, connection reliability, etc.).
Unread 06-11-2011, 18:09
Yes. With 6" wheels, at least 1.8x more reduction would be appropriate. For 8" wheels, make that 2.4x additional reduction.
Unread 06-11-2011, 20:51
Can you time this to see what the actual number is? And if it is close to one minute, can you give language details?
Greg McKaskle
Unread 07-11-2011, 07:57
The loose negative power supply lead and the improper wiring for the radio are enough of a smoking gun for me. The battery will regularly drop to eight volts in a complete direction reversal. All motors are going through excessive current draw so the voltage drop across the internal resistance of the battery and the wiring and breaker feeding the PD is enough to cause this in four motor drives. The three terminal regulator is only speced to maintain output voltage down to about seven volts input. It is for this reason, the voltage regulator must be wired to the 12 volt radio output of the PD. That output will maintain voltage down to about 4.5 volts on the battery input.
Unread 09-11-2011, 11:51
FRC #1747
I apologize for the lack of communication on my end. I actually had one of the members post this up for me and I never found the actual thread.
But yes, thanks to Mr. Reffler, we did do some troubleshooting, as he said.
Now, there ARE 3 Bane Bot Motors on the system, but I have no idea when they were ordered, but they were definitely before the 2011 season.
We are currently off of school for the week, but once we get in, I'll switch the radio over to the dedicated port and check our motors for the case short.
I'll update you guys once I can do the few tests and possible fix, now that I know where this thread is.
Thank You All Very Much For Your Help!
UPDATE
Now that I think about it, the Bane Bots Motors are the unlikely cause of the problem, because they aren't running when the radio resets itself. It's the CIM Motors that are the most probable cause.
@Ether, could you please explain to me what you mean by a 2.4X reduction? We are using 8" Mecs and I believe the ratio is 1:3 or some absurdly low number.
UPDATE
btw, to answer Mr. McKaskle's question, we do get connected back to the robot, but after a good 5 minutes. It's definitely a radio reset. Furthermore, we are using Java and running cRIO image version 28
Unread 09-11-2011, 12:29
If your radio is taking 5 minutes to reconnect to the field, then it could be that the manual switch on the back of the DLink is in the Auto position rather than Bridge.
Unread 09-11-2011, 12:46
Have you rewired the robot since competition, or were you able to pass inspection twice with the radio wired to a PD breaker?
