Go to Post I care that teams took some time to put in safe guards to prevent shrapnel hitting people because I'm selfish and I enjoy the use of all of my limbs. - Andrew Schreiber [more]
Unread 07-11-2011, 19:15
AdamHeard's Avatar
Lead Mentor
Re: pic: FRC488's Octocanum Ver 2.0
Other than closed-loop speed control of the 4 wheels (did you do that?), what other closed loop controllers did you use for controlling the drivetrain?
Wouldn't measuring the vehicle's actual velocity be more useful? After all, the drive has no care as to what wheel speed is (especially if that wheel is slipping).
Unread 07-11-2011, 19:20
Originally Posted by JohnGilb View Post
Rotational - used a gyro to keep the robot on target heading
Translational - used encoders on "follow wheels" (unpowered wheels) to gauge ground speed and keep the robot translating on a target vector
Were these controls presented to the driver as the interface? i.e., did the driver interface allow the driver to command for example "Translate in direction A with the vehicle pointing in Direction B" ?
Unread 07-11-2011, 20:45
JohnGilb JohnGilb is offline
Programming Mentor, Drive Mentor
FRC #0488
JohnGilb has a spectacular aura aboutJohnGilb has a spectacular aura aboutJohnGilb has a spectacular aura about
The driver had two joysticks:
1st: X/Y joystick movement controlled X/Y direction & magnitude of the robot relative to the field
2nd: X joystick movement controlled rotational rate relative to the robot
So, not exactly what you described, but fairly close.
Unread 07-11-2011, 21:15
OK, so let me read back to you what I hear you saying:
- You do closed-loop control of the vehicle speed as commanded by the radius1 of joystick #1
- You do closed-loop control of vehicle heading as commanded by the angle2 of joystick #1
- You do open-loop command of rotation rate as commanded by joystick #2 (X, Y, or Z axis?)
Am I understanding you correctly?
How many follower wheels did you use, and how are they mounted?
1 Do you use sqrt(X^2+Y^2) or max(abs(X),abs(Y))?
2 Do you use atan2(X,-Y) to calculate angle, or something else?
Unread 08-11-2011, 03:08
FRC #0488
Sorry, I think something got lost in my description.
-We perform closed loop control of X translation as commanded by the X axis of Joystick1
-We perform closed loop control of Y translation as commanded by the Y axis of Joystick1
-We perform open loop control of Robot rotation rate as commanded by the X axis of Joystick2 (however, when desired rotation rate is 0, we perform closed-loop control of robot angle as commanded by the heading we were at when we stopped rotating)
This was accomplished with 3 follow wheels and a gyro. Two of the follow wheels were used to track the robot moving forward/backward, and one was placed directly under the center of rotation and used to track the robot strafing.
Unread 08-11-2011, 08:48
pfreivald's Avatar
AKA: Patrick Freivald
An interesting design! We've used mecanum for the past two years and were very satisfied with it in many respects, but know that it needs some push to really up our competition level. Thus, we've been working on our own drive (though I didn't know it had a cool name like 'octocanum') which is similar in idea to this.
Thanks for sharing! (And great questions everyone. This is a good thread to follow for anyone considering such shenanigans like we are!)
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 08-11-2011, 10:56
OK that's pretty clear, thanks.
Were the forward/backward follower wheels mounted like this? And, I assume they were omni, correct?
Did you ever consider, or try, using the data from the follower wheels to compute rotation rate?
Unread 08-11-2011, 13:17
FRC #0488
Ether, your follow wheel mounting assumption is correct. They were positioned as in your diagram, and they were omniwheels.
We did use them to calculate a rotation rate, let's call that Rotation_Follow. We also had rotation from the gyro, let's call that Rotation_Gyro.
We found that Rotation_Follow wasn't as good as the Rotation_Gyro, we suspect due to minute wheel scrub and small errors accumulating, but it did not suffer from drift. Consequently, we used Rotation_Gyro exclusively, but ignored any change in rotation while Rotation_Follow was 0 (typically at the start of the match before the robot was moving anywhere, or during testing when the robot spent a lot of time on a bench or disabled). This eliminated a large part of our gyro drift.
Unread 08-11-2011, 13:55
I like it. Nicely done.
Unread 08-11-2011, 14:19
Jared Russell's Avatar
Taking a year (mostly) off
This is a clever solution. A Kalman Filter would be another good way to combine accurate (but drift-prone) gyro measurements with less precise (but stable) odometry measurements.
Unread 08-11-2011, 14:48
FRC #0488
We tried a number of filters (Kalman was unfortunately beyond my reach, never had a strong grasp on linear algebra), but they turned out to be unnecessary - the gyro we used (don't have the model # on me) was incredibly accurate - it usually only drifted ~3 degrees over the course of each match, even through collisions.
The "stationary detection" we did was only necessary when the robot was put on the field but the start of the match was delayed several minutes (yeah, we've all been there).
Unread 08-11-2011, 14:52
AdamHeard's Avatar
Lead Mentor
Mind sharing the model number of that gyro?
Also, you didn't use the pair of follower wheels to try to determine rotation rate while translating, you just used it to detect the complete absence of velocity, correct?
Unread 08-11-2011, 15:04
The point midway between the translation follower wheels was said to be the center of rotation of the vehicle. To the extent that is true*, you could extract vehicle rotation while translating.
*The center of rotation likely shifts around especially if weight distribution changes as manipulators move.
Unread 08-11-2011, 15:08
AdamHeard's Avatar
Lead Mentor
Wouldn't that only be true while not translating? Translating would shift the center of rotation, would it not?
Unread 08-11-2011, 15:26
theprgramerdude theprgramerdude is offline
WPI Freshman
AKA: Alex
FRC #2503 (Warrior Robotics)
theprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud of
What's the maximum speed at which you can switch between Mecanums and high-traction wheels? Plus, about many switches can be performed before there becomes a serious air deficiency such that it is unreasonable to switch at all, assuming you have about 3-4 tanks at 120 PSI at the start.
Attending: MN Duluth Regional
