Go to Post Whether or not you use wheel weights, if you're running a wheel at several thousand RPM, you'd better have an effective containment system to protect the outside world in case something spontaneously disassembles itself. - Alan Anderson [more]
Unread 11-12-2001, 19:52
Tom Schindler's Avatar
Tom Schindler Tom Schindler is offline
Now an AIR Striker....
FRC #0078
Tom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond repute
Send a message via AIM to Tom Schindler
Speed Controllers...
Does anyone know of a speed controller that will accept an analog voltage (0-5V) as its input??
Thanks
Tom
Unread 11-12-2001, 22:03
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
NO!
If I recall correctly, the speed controllers are expecting a short pulse every 20msec or so. They accept a relatively wide range of base frequencies. The important thing is the pulse width. I believe that a 2msec pulse width is full stop. 2.5 msec pulse is full forward and 1.5 msec is full reverse.
I am going strictly from memory so don't quote me. The idea is right but the absolute numbers are probably wrong.
In any case, this is not too hard to make a "555" timer circuit that would turn a voltage of 0-5 into the right pulse train. I suppose that there are even custom IC's that would do it for you. Better yet, if you have an extra Stamp2 laying about you can fairly easily make it do the interface for you.
Good luck,
Joe J.
Unread 12-12-2001, 17:35
FRC #0078
Joe,
Not sure if you misunderstood me, i was not planning on running 5 volts into a victor
The PWM signal has a 17 ms period with a pulse width from 1-2 ms. A pulse of 1.5 ms is considered neutral.... I was wondering if anyone knew of different kind of speed controller that would accept this a 0-5v input, or, as Joe pointed out.. a way to transfer 0-5V into the correct pulse
Unread 13-12-2001, 13:20
ChrisH ChrisH is offline
Generally Useless
FRC #0330 (Beach 'Bots)
0-5v
I don't know about speed controlers, but we used to control temperatures with a 0-5v circuit. Most equipment has gone to 4-20mA. At least then you know if the signal gets lost. I would assume there would be something out there if only for replacement parts on existing equipment.
ChrisH
Christopher H Husmann, PE
"Who is John Galt?"
Unread 13-12-2001, 17:26
Electrical Engineer
Rookie Year: 1995
Tom,
There motor drives for DC brushless motors which take 0-5V, 0-10V and/or 4-20mA inputs.
I had inquired with innovationfirst about an analog input (for a past project we were working on) and they had indicated that, yes, they could do it (OEM basis).
However, after I had a bit of time to think about it, I came to the conclusion that a digital interface would be more noise immune.
In the end, I went with a DC brushless motor with a conventional motor drive and 4-20 mA input. It was much more versatile for the rapidly changing requirements of that development effort.
Now, back to your issue... What's the size of your load? If it's small, a DC/DC converter "brick' with a variable output may do the trick. They have current limiting and everything...
Bottom line, the IF speed control is a pretty good package and I don't know of anyone who makes a 0-5V input AND you already know a lot about the IF controller. I would agree with Dr. J... a 555 timer is a piece of cake. You can buy them at any Radio Shack.
Mike
Mike Betts
As easy as 355/113...
initialization program and speed controllers rosebud Programming 15 05-10-2004 03:35
speed controllers & circuit breakers deuceswild Electrical 2 15-01-2003 14:46
speed controllers archiver 2000 5 24-06-2002 00:19
Capacitors on speed controllers archiver 1999 7 23-06-2002 22:09
Calibrating speed controllers and joysticks thedillybar Technical Discussion 4 11-02-2002 13:24
