Go to Post And now I'll just take a moment and say that you've all gone completely insane. That is all. - galewind [more]
Unread 10-11-2011, 20:12
inou8it inou8it is offline
Captain/Founder/Student
inou8it has a spectacular aura aboutinou8it has a spectacular aura about
Solenoid help
We are trying to use Solenoid Valve VUVG-L10-B52-T-M7-1P3 by supplying it power from our 12V battery and it does not work as intended although it does receive signals from the CRIO and lights up. The data sheet says it requries 24V although they gave this to us in our kit of parts, why would they do that if it couldnt be used with 12V of power? Thanks for the help!
Unread 10-11-2011, 20:34
Jon236's Avatar
Jon236 Jon236 is offline
AKA: Jon Mittelman
FRC #2648 (Infinite Loop)
Jon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond repute
Re: Solenoid help
If you supply 24 volts from the Power Distribution Board to the solenoid module, you will find that your valve will work just fine.
Jon Mittelman
Senior Judge Advisor New England & Israel 2014-2015
Infinite Loop Mentor 2011-2015
TechnoTicks Mentor 2000-2011
Championship Chairman's Award 2009 Team236 TechnoTicks
Judge 2010-2015 Championships
Senior Judge Advisor New England District Championship 2014-2015
Judge Advisor Tel Aviv Regional 2007-2015
Judge Advisor Pine Tree Regional 2013
Maine Regional Planning Committee
New England District Planning Committee
Lead Inspector Microsoft Tel Aviv Regional 2006-2008
Judge & Lead Inspector GM/Technion Tel Aviv Regional 2006
Judge UTC Hartford Regional 2006
Unread 10-11-2011, 20:37
theprgramerdude theprgramerdude is offline
WPI Freshman
AKA: Alex
FRC #2503 (Warrior Robotics)
theprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud of
Re: Solenoid help
The solenoid valve isn't meant to be powered with 12VDC straight from the PDB; instead, as shown on the alternate power diagram on the FIRST website, the 24VDC is supposed to be supplied from the Crio solenoid output module.
This is achieved by also hooking up the PDB boost converter that hooks up to the main supply on the Crio to the solenoid module; this module then sends the 24VDC power to the solenoid as governed by your code.
Attending: MN Duluth Regional
Unread 10-11-2011, 20:38
Re: Solenoid help
the only 24V we see is from the CRIO into the board can we branch off of this safely?
Unread 10-11-2011, 20:48
Re: Solenoid help
Teams may power one Solenoid Breakout Board from the 24Vdc regulated supply on the Power Distribution Board that is also used to power the cRIO.
Power the 24V solenoid from the Solenoid Breakout Board.
Unread 10-11-2011, 21:12
WPI Freshman
AKA: Alex
Re: Solenoid help
To elaborate, the Solenoid Breakout Board is the module that normally went in the 8th slot on the 8-slot Crio. The PD board connects the 24V to that, and then standard 2/3-wire PWM cables connect out of this to the solenoid to actuate it.
Unread 10-11-2011, 23:07
Re: Solenoid help
thanks for the help!
