Go to Post Good story telling and animation know no age limits. - BMiller2559 [more]
Unread 11-11-2011, 08:37
Brandon Holley's Avatar
Brandon Holley Brandon Holley is online now
Re: [DFTF] Motors... ...Drive Motors...
I consider 4 CIMs in the DT a minimum as far as motor power is concerned. I would start there as a baseline.
In 2008 we built our drive system to use 6 motors in total, 4 CIMs and 2 FPs. We did not shift, but we were still able to move pretty quickly around the track. I've seen a gradual increase in the number of 6 motor drives over the past couple of years, but its still rarely used.
I cannot speak to using 775s in a drive system, but I will tell you that they caused NOTHING but problems for us in our elevator this past season. I think we went through 8 or 9 motors and each and every one of them was case shorted. This in turn caused widespread electrical issues such as causing servos to twitch (launch minibot prematurely) and smoking Jaguars. We will avoid them as best we can moving forward.
The FP has changed several times over the years, and I think the newest iterations are much more robust than their smoking older siblings. I wouldn't hesitate using a FP in most applications now.
-Brando
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
Unread 11-11-2011, 09:04
JamesCH95's Avatar
JamesCH95 JamesCH95 is online now
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
How were the motors setup? Transmissions, loads, control, etc. Like I said my team had a 100% positive experience with them, so I'm curious as to why your experience was 100% negative.
Unread 11-11-2011, 09:20
We used 2 to run our elevator winch. The winch was close to the bottom of the robot, and powered a ~12" long aluminum drum that would wrap up the sailing line in our elevator.
The winch itself had each 775 powered through a "CIM-U-LATOR" and then further reduction inside a gearbox where the motors were paired. I'm not sure of the overall ratio off the top of my head, I can report back later. We did quite a bit of math to make sure we would be geared for an appropriate speed. Additionally about 75% of the weight of the elevator (and claw system) was offset by spring force. To say this thing was overpowered would be an understatement.
When we had functioning 775s, the elevator ran up and down with few issues. Unfortunately we never had one 775 that functioned flawlessly. Even if we confirmed there was no case short when installed, the motors tended to develop them over time. It wouldn't take long either. We checked the case short after each and every match to basically gauge how long we could continue running that set of 775s before needing a different pair. After each match we would watch the resistance drop until finally we would have issues with the minibot deployment which signified an end of life for the motor.
We tried to isolate the motor from the robot by placing dielectric sheet between the face of the motor and the gearbox plate. We also tried wrapping screws in teflon and then installing them. The short went through the motor pinion, into the CIMULATOR gearbox, through the CIMULATOR output shaft into our custom secondary gearbox, through the output shaft, through the bearings pressed in the plate that the shaft ran through, into the gearbox plate and the gearbox plate mounting screws, and finally into the frame of the robot. It was a nasty problem to have.
"Zapping" the motors was a common practice teams used to fix this issue, and we did so as well. On some motors it would definitely enhance their lifetime, on others it didn't do much of anything. It was almost kind of sad how good we got at pulling the motor off the robot, "zapping" it, and then replacing it. We often did this process, or a full replacement of the motors in-between matches.
If Banebots can show us that this isn't going to be a reoccurring issue, then I would say we'd be open to using the motors again. Like I said, when they worked, they worked perfectly fine. However, it was my understanding that Banebots essentially said the issue was minor and recommended the "zapping" process.
I will add that we used a pretty well tuned PID loop to control our elevator. We did a pretty good job about handling stall though. There were several timeouts built in that would cut power to the motors after a couple seconds of stall and ensure we weren't just driving around with the motors humming.
Just our experience with them. I know others who have had success with them, and I know others who dealt with the same issues we did. It seemed to be luck of the draw this past year.
-Brando
Unread 11-11-2011, 12:10
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
This is a perfect scenario that would benefit from loosened motor rules. The Banebot RS775 motor is an exact clone (specification wise) to the RS-775WC-8514 motor produced by Mabuchi, with the only difference being the cost/quality of the motor construction.
Art Dutra IV
世上无难事,只怕有心人.
Unread 11-11-2011, 12:56
Does anyone know who is the manufacturer of the Banebot RS775 ?
Unread 11-11-2011, 13:17
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
I'd bet the lowest Chinese bidder, not a real brand. I wouldn't be surprised if the variations in performance were linked back to different suppliers or different lots of motors.
Unread 11-11-2011, 10:17
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Interesting... our experience this past year with them is exactly opposite. I can't even count the number of FP's we burned up with our elevator this year. In the off season here, we stopped buying the "new" ones that were legal this year, and instead threw on an old one from 2008, as it was just sitting there. Haven't had a single problem with it since, and that includes a full day of playing matches at an off season event (only 10 teams were there too, so we were on the field almost every other match). This years FP's would last maybe 2 rounds in the eliminations at North Star this past year.
Unread 11-11-2011, 10:42
That is interesting.
In all honesty I don't know a lot about the actual difference between each years FP motor. I do know that it has tended to be different almost every year for the past few years.
If I recall correctly we were given only 1 of the FPs this year, and it was a significant step up in power.
We placed it in our roller claw and absolutely no problems with all year. In the past we've used them in various systems (elevators, hopper systems, drive trains), and as long as you didn't stall them, they worked fantastically.
-Brando
