Re: What programming Language To Use??
Your ONE programmer knows C.
If this ONE programmer is the only ONE who will program this year, then C++ is the way to go. If you are planning on having more programmers, especially those who haven't programmed much before, then LABView is an easy language to learn, so I hear. OR, if your current ONE programmer is capable and willing, they could teach others how to program C++, however it is tough to find a good teacher in most students when it comes to programming C++. Notice the ONE word I put in all caps? My little bit of advice to you: If you can, have more than ONE programmer. It's an important job that requires lots of work and skill, and for some strange reason robots won't run without it. ![]() |
With the templates provided, you will find that you can program a robot easily in any of the 3 languages supported. I have found that debugging is easier in Labview. You should also look to the teams nearby. It is important for FRC teams to help each other, so ask!
ok thank you
Because the language you choose is [usually] the first language your programmers will learn in, I would recommend against LabView, but if you can't get a mentor or student who knows a different language, then LV is the way to go until you train students in a different language.
To address the original poster, I vote for Scala . |
#8
I'm still much more comfortable with Java (OOP) so I would say yes it does matter. Also, being skilled in using Java holds a lot more weight then an obscure language such as SML. Not being comfortable with C, C++, or Java will make scoring an internship at a software company much harder. In the current job climate, graduating from a CS or Software Engineering program without any industry experience is not going to make finding a job easy. As an interviewer, a candidate without any industry experience would make me uneasy. I'd say that being comfortable with an OOP language is much more of a necessity then a functional language although learning a functional language does help expand on a lot of CS concepts.
#10
Folks,
Bear in mind here that the object of FIRST is not to produce software engineers; it is to inspire kids to get interested in STEM careers. If we can get them hooked with Labview or Java, that's all to the good. I think the key here is not to let the kids founder. The team needs to pick a programming tool that is well supported and that a mentor can help them with. FIRST does a great job producing tools in all 3 supported languages. Every team should have a mentor (either close or on-line) that can help them succeed. |
#11
#12
No. But If I had spent my early years at college working with SML over a language such as Java, it would have made getting an internship really hard.
#15
I think that, rather than the order in which the languages were studied, would explain why you are still much more comfortable with Java (OOP).
