Go to Post I wouldn't mind having this day repeat itself a few times. It would give us more time to work on our robot. - Mr.D [more]
Unread 13-11-2011, 17:49
flameout flameout is offline
AKA Ryan Van Why
FRC #0957 (SWARM)
flameout is a name known to allflameout is a name known to allflameout is a name known to allflameout is a name known to allflameout is a name known to allflameout is a name known to all
Mecanum wear and dirt resistance
I am considering presenting the idea of switching our T-shirt launcher over to mecanum to Team 957. Before doing so, I would like to have a definite list of pros and cons (as we have never done mecanum before).
While there are many threads discussing mecanums in the context of competition, I have a few concerns specific to this robot that I have not found adequate information on.
Here are my primary concerns:
1) Wear. We will be running this bot a lot, often on asphalt and other abrasive surfaces. We'd rather not have to periodically replace wheels (even once a year would be too much), although, if necessary, we might be willing to switch out the rollers (if they can be made/obtained cheaply) every year or so.
2) Resistance to dirt. We do not always run the robot inside, and it is not uncommon to have it running right on dirt (or being pushed over the dirt). I'm afraid that the dirt may gum up the bearings.
3) They must not damage gym floors. We often run our robots on gym floors -- the kitbot wheels work fine for this, but other types damage the flooring. This is likely to be a smaller issue than the others (as mecanums don't typically skid very much), but it's still a consideration.
EDIT: Let's remove this from the topic of this conversation, as mentioned in post #3 -- we'll do our own testing to verify that a specific roller material does not damage the floors prior to ordering a set of wheels.
In terms of machining (for creating replacement rollers if it's necessary), our team isn't very capable. We have neither a lathe nor a mill, and have no experience with casting parts. However, we have a sponsor with a high level of machining capability who would be able to machine roller casts for us, as long as it is a one-time deal.
How valid are each of these concerns (particularly 1 & 2)? Do you have a recommendation for a particular style of mecanum (with respect to these concerns)?
Please don't discuss mecanum vs. tank-style drivetrains -- let's keep this thread centered on the practicality and implementation of mecanum on a robot with the usage scenarios outlined above.
Thank you.
Unread 13-11-2011, 18:03
Tom Ore Tom Ore is offline
FRC #0525 (Swartdogs)
Tom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond repute
Re: Mecanum wear and dirt resistance
1) I think you will see significant wear on the rollers
2) Dirt could get under the rollers, making them sticky and maybe increasing wear
3) We always put down carpet whenever we run on a surface that needs to be protected. We also put down carpet when we demo outside with our competition robots. (We keep an old roll we inherited at our shop.)
If you do you run mecanums, buy a set rather than trying to make them.
Unread 13-11-2011, 18:15
AKA Ryan Van Why
FRC #0957 (SWARM)
Do you have any experience to back this up?
Would this be an issue in terms of driving performance? Is this a problem that applies more to some mecanum styles than others?
To clarify, by "styles," I'm mainly referring to how the rollers are mounted -- I've seen rollers mounted on the ends (like AndyMark does with their wheels), and rollers that are mounted in the middle (like AirTrax uses).
Unfortunately, this is not feasible for our team. However, now that I've looked at it, it appears as if AndyMark's rollers can be bought individually -- we'll do our own testing before purchasing whatever roller material we choose to use if we choose to do mecanum (so I'll remove this from the focus of this thread).
We need to be able to replace the rollers cheaply. Are you suggesting buying the initial set off-the-shelf and manufacturing our own replacement rollers, or do you know of a source for replacement rollers that we don't know about?
Thanks for the help.
Unread 13-11-2011, 18:22
Consider what happens when you're straffing. The rollers will be scrubbing and thus wearing.
Unread 13-11-2011, 18:24
AKA Ryan Van Why
FRC #0957 (SWARM)
What do you mean by "scrubbing"? My understand was that, in mecanum, slip would only occur when applying a large force -- such as accelerating, decelerating, or pushing against something external.
Am I wrong about this?
Unread 13-11-2011, 18:38
Scrubbing is sideways motion on a wheel. Take any wheel, hold it on the floor and push it sideways - you'll get wear. When a mecaunum robot is straffing sideways the rollers are scrubbing. You don't even need pure straffing - any time you turn you'll get some scrubbing.
Unread 13-11-2011, 18:44
AKA Ryan Van Why
FRC #0957 (SWARM)
So by this definition, scrubbing isn't a problem (as a design feature of mecanum wheels).
To those teams who have used mecanums before, how much wear did you see and how much did you use the wheels? Have any of you run your wheels extensively in dirt and not had issues (or had issues)?
Unread 13-11-2011, 18:50
On carpet, the scrubbing doesn't cause any wear. If you use mecanum wheels on pavement and dirt please let me know how it goes - I would expect you're going to see wear. (By the way, we've used mecanum wheels - we have 4 regional wins on mecanum wheels.)
Unread 13-11-2011, 18:55
AKA Ryan Van Why
FRC #0957 (SWARM)
So you saw 0 wear on carpet (through the lifetime of your robot), but haven't run it on anything else?
We have no intention of trying mecanums on grass -- we don't drive our current robot on grass either. Dirt, asphalt, and gym floors are unavoidable for us, however.
This is not true Tom. If the rollers are free to spin, there is no scrubbing, even when strafing.
If you rotate the mecanum as you push it sideways, there will be no scrubbing. That is how a mecanum works. Try it.
Unread 13-11-2011, 19:06
AKA Ryan Van Why
FRC #0957 (SWARM)
Thanks -- I was 99% sure about this, but wanted verification since Tom seemed so sure that scrub would occur even during low-acceleration conditions.
Unread 13-11-2011, 19:12
Ankit S.'s Avatar
Ankit S. Ankit S. is offline
FRC #2489 (The Insomniacs)
Ankit S. has a spectacular aura aboutAnkit S. has a spectacular aura about
Over the past 11 months our robot has probably ran for about 5 hours on asphalt, 4 of which during the same day. We also had about 6 hours of drive time on carpet. Our wheels are doing fine, and we have not had switch anything out.
The one thing that I would suggest, however, is to clean the vicinity of the wheel every now and then, as that can get pretty dirty.
Edit: We used the 8" wheels from AndyMark, and all the parts used for the wheel were COTS.
FRC 2489 - The Insomniacs
Alumnus
2489, 3189, & 701 - The Green Alliance - 2013 Sacramento Regional #6 Alliance Captain and Champions!!!
971, 254, & 2489 - 2011 CalGames Champions. Thanks 254 and 971!!!
Unread 13-11-2011, 19:15
sithmonkey13's Avatar
sithmonkey13 sithmonkey13 is offline
AKA: Nathan
FRC #1178 (DURT)
sithmonkey13 is a name known to allsithmonkey13 is a name known to allsithmonkey13 is a name known to allsithmonkey13 is a name known to allsithmonkey13 is a name known to allsithmonkey13 is a name known to all
For use on carpet and gym flooring, meccanums should be fine, with normal wear and tear. However, depending on the surfacing of asphalt/concrete, your rollers could get torn up pretty badly.
Note: You cannot tell the difference between "OK Go" and "OK No" when there 2 walls between you and the robot. At that point, the only thing between injury and safety for the mechanical guys is their ninja skills.
Unread 13-11-2011, 19:25
Ankit S.'s Avatar
The AM rollers are pretty strong, the asphalt outside our workspace is not the best, but they still held up to the 4 hours of driving that we did.
If you do have any worries though, you could purchase extra rollers, they are not too expensive, and you should not need to switch them out more than once every 24 hours of drive time on bad ground.
One thing I need to ask though, is there a reason why you want to use mechanum wheels? Sure it can turn a lot easier, but it really is not the best for a really uneven surface, as the vectors may not cancel out properly...
Alumnus
Unread 13-11-2011, 19:30
The rollers aren't necessarily free to spin. Some spin fairly well, others are sticky, some are stuck. The newer AM mecanums seem to be more consistent than the older ones. Breakaway was rather rough on the mecanums - bouncing down the back side of the bump bent the screws holding the rollers and the rollers would stick.
