Go to Post Valentine's day, who has time for Valentine's day?????? I have code to write!! - paulcd2000 [more]
Unread 14-11-2011, 10:37
PhilBot's Avatar
PhilBot PhilBot is offline
Get a life? This IS my life!
AKA: Phil Malone
[FTC]: Easy way to insert tank tread rubbers?
Hi
Has anyone found an easy (read... not excruciating) way to insert the rubber treads onto the plastic tank tracks?
We've tried soapy water, pushing, pulling etc. It's still pretty difficult & we've destroyed several treads in the process.
BTW... if you purchased your treads more than a month or so ago, you may have a batch of treads that have a manufacturing defect in many of the pieces.
If you look at the treads from end on, there should be a rectangular hole all the way through the tread. Many of the older treads have a bump of plastic in the middle of the tread that totally prevents you from inserting a rubber insert.
I called PITSCO on this and they said they now have the problem under control, but they sent me a bag of replacement treads. I had to send the old ones back, and in doing so discovered I had 140 BAD treads...!!!!!
Phil.
Phil Malone
http://www.GEARSinc.org
Unread 14-11-2011, 13:15
Andrew Remmers's Avatar
Andrew Remmers Andrew Remmers is offline
AKA: Andrew Remmers
Andrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond repute
Send a message via AIM to Andrew Remmers
Re: [FTC]: Easy way to insert tank tread rubbers?
I haven't done to much playing with the rubber inserts, however I think cooling and heating might bring success. Its worth a shot at least. Stick rubber links in the freezer for a night and microwave the plastic for a few seconds when ready to assemble?
Thats what I would try first.
- Andrew
Exploding Bacon 2007-2011
Built and Dangerous (B.A.D) 2011-2012
Community Mentor / School Break 2012-2014
North American Robotics: The MooseEagles Founding Member 2012-Present (VEX U)
Unread 14-11-2011, 20:53
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
Undiluted dish washing liquid.
Unread 15-11-2011, 17:58
missmurrea missmurrea is offline
FTC #5132
missmurrea is an unknown quantity at this point
Dish washing soap with no water added. That's what we used. But it takes a few days to dry, in the mean time, if you try to drive the robot, the rubber parts slip out and they have to keep getting adjusted
Unread 15-11-2011, 20:43
Joachim Joachim is offline
Joachim has a spectacular aura aboutJoachim has a spectacular aura aboutJoachim has a spectacular aura about
A team I mentored used needle-nose pliers to grab the external part of the inserts along the entire insert length (which is in the direction of the tread width), then "pulled" the inserts into the tread pieces.
Unread 16-11-2011, 00:01
AKA: Alan Wells
FRC #1350 (Rambots)
If you rinse them off with water after the tread pieces are inserted, the residual slip should be reduced or eliminated and the drying time should also be reduced (water evaporates faster).
Unread 16-11-2011, 02:00
VashonRobotics's Avatar
VashonRobotics VashonRobotics is offline
AKA: Bruce
FTC #3861 (Vashon Pirates)
VashonRobotics is an unknown quantity at this point
We successfully got them in using two people, one pulling with hemostat clamp and the other pushing with fingers all at room temperature and dry. After we got going it took only about 15 seconds per tread. We tried soap and all but I think the hemostats were the key, small enough to clamp yet not so big that it compressed and thereby enlarged the tread when clamping. Anyway worked for us.
Unread 17-11-2011, 19:00
normalmutant's Avatar
normalmutant normalmutant is offline
AKA: Nathan
FTC #3539 (Say Watt?)
normalmutant has a spectacular aura aboutnormalmutant has a spectacular aura about
Soap or pliers or both.
SAY-WATT.ORG
Unread 26-11-2011, 22:14
pbesen pbesen is offline
FTC #3167
pbesen is an unknown quantity at this point
we tried all the above tricks. The one that worked the best was placing the treads under a hot air popcorn maker (hot air on treads). Not so close that they melt.
After a minute or so, they soften and can be easily inserted (most of them).
Unread 29-11-2011, 09:50
blhenze blhenze is offline
Bernie H
FRC #2333 (Sapulpa Chieftain Robotics)
blhenze is an unknown quantity at this point
When I examined the track, I found that about half of the track had a small bit of plastic on the inside that kept the rubber tread from being inserted. The good track was sorted from the track that had the extra plastic. We used the good pieces for inserting the tread and the bad pieces as between pieces in the track (every other track piece had an insert). Lego said they would replace the "bad" pieces.
Unread 29-11-2011, 11:20
PhilBot's Avatar
AKA: Phil Malone
Yeah, That was where I kinda started this thread
Phil Malone
Unread 29-11-2011, 11:41
PhilBot's Avatar
AKA: Phil Malone
Just to clarify: Did you hear the black plastic track pieces, or the grey rubber treads...
Phil Malone
Unread 29-11-2011, 17:32
French~Fries French~Fries is offline
FTC #3787 (Green Exploding Volcano Monsters)
Team Role: Webmaster
French~Fries is an unknown quantity at this point
Our team used tank treads last year, and I'm afraid to say that after trying all of the above-mentioned methods, we were reduced to using our teeth. I should also mention that it's best not to put treads in every piece of track. Do every other piece, or even every other two or three.
Unread 01-12-2011, 23:27
PhilBot's Avatar
AKA: Phil Malone
What is the reason for not putting tread in every track?
Phil Malone
Unread 02-12-2011, 02:01
Garrett.d.w's Avatar
Garrett.d.w Garrett.d.w is offline
Build Lead
FRC #2733 (The Pigmice)
Garrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to behold
While I haven't inserted tread on track feet, I have had the pleasure of inserting aluminum shaft into surgical tubing (for use as tread on our minibot). This sounds similar to your problem (wanting good lubrication, without a long drying time).
What we found works best for anything that requires temporary lubrication is Windex. The cleaning solution lubricates for about a minute before evaporating.
"A mind once stretched by a thought will never regain it's original dimensions."
Optimists think the glass is half full.
Pessimists think the glass is half empty.
Engineers realize it's twice as big as it needs to be.
