Go to Post we are all in the same boat. We'll adapt and deal with the challange. No need nashing teeth over the little stuff... - wilsonmw04 [more]
Unread 15-11-2011, 00:13
Chris_Elston's Avatar
Chris_Elston Chris_Elston is offline
Controls Engineer
AKA: chakorules
FRC #1501 (Team THRUST)
Chris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond repute
Re: Google Sketchup
As everyone has said, Sketchup is great for concepts. It's also great to check dimensional data very quickly, to see if it's possible.
I guess let me lead by example to show this off. Here are a couple of a concept sketches we made in the past seasons.
In 2010, there was a 3 inch rule, we wanted to quickly see what that meant so we used google sketchup to see a picture of what this rule looked like.
In 2011, the same with the 80 inch rule, several of us did not know if there was enough room to design a gripper, once again using sketchup to show it's gunna be ok...
In 2011, we wondered if a robot could fit between the mini-bot pole and wall and a few other things, again sketchup helped us see visually the design constraints and moved into CAD after that.
Credits: In the 2011 the field was drawn by someone else here at CD, we downloaded it and used it. Thank you who ever you are.
ID:	11072  Click image for larger version
ID:	11073  Click image for larger version
ID:	11074  Click image for larger version
ID:	11075  Click image for larger version
Team T.H.R.U.S.T. 1501
Download all of our past robot's source code here:Repository
Favorite CD quote:
"That can't be their 'bot. not nearly enough (if any) rivets to be a 1501 machine." ~RogerR: Team #1369
Unread 15-11-2011, 07:29
scottydoh scottydoh is offline
CAD, Mechanical, Alumni, Mentor
AKA: Scott
FRC #0810 (Mechanical Bulls)
scottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to all
Send a message via AIM to scottydoh Send a message via Yahoo to scottydoh
Re: Google Sketchup
Originally Posted by Tetraman View Post
I would define Sketchup as a sandbox game - whereas you are given a set of simple tools to play around with simple shapes. It's perfect for beginners and for getting quick ideas down. And there are some advanced capabilities that can be applied given time, lots of time. Give yourself enough time and you can use Sketchup the same way you could use other programs.
A Computer Aided Design program is not a sandbox game. You are not limited by the capabilities of the program, but instead by your willingness to dig deeper into Inventor and/or Solidworks and get the result you are looking for.
That's a fair answer. Thanks.
www.smithtownrobotics.com
Robot Inspector (SBPLI 2011)
2011 Johnson & Johnson Gracious Professionalism (NYC) Judges Award (SBPLI)
2009 Xerox Creativity (SBPLI)
Mechanical Bulls; Student Leader 2006-2008, Mentor 2009-Present
New York Institute of Technology - Architecture '13 | Design Portfolio:www.coroflot.com/sdifiore
