Go to Post Got Valentine's day present from wife before leaving for work. Non-contact IR thermometer, two unscuffed pairs of safety glasses for competitions, bag of York peppermint patties. She understands me. - Greg Young [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 15-11-2011, 21:29
Glitch_94's Avatar
Glitch_94 Glitch_94 is offline
AKA: Harrison Shipp
FRC #3374 (RoboBroncs)
Glitch_94 is an unknown quantity at this point
Questions about 80/20
Okay, So my team is thinking about using 80/20 for our robot this year and wanted to know how other teams felt about using it. Was it easier than C channel and angle? Is it good to order a kit from the site or design our robot and order it? Any suggestions would be awesome! Thanks!
Unread 15-11-2011, 21:39
Tetraman's Avatar
Tetraman Tetraman is offline
FIRST on my mind
AKA: Evan Raitt
Tetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond repute
Re: Questions about 80/20
Pro: Very easy to build with
Con: HEAVY AS ELEPHANTS
174 uses 80/20 for our initial robot designs or for the parts we need to be super sturdy. We build up one robot with the 80/20, getting all the tweaks out and seeing in real life what we have designed. But once we have that all set, we build a second robot, with the 80/20 swapped with O, C and L channel when appropriate and weld the channel together to save on additional fasteners. It takes away so much weight while still keeping to the size of the 80/20. However, I don't think we could ever do what we do with the O, C and L channel without using 80/20 first.
Is 80/20 easier than C channel? Yes. Is it better? ehhhhhh....
My personal suggestion would be to get enough to test out on a chassis or a tower for an arm, and then decide later how you wish to go about using it more or less. I would definitely suggest at least giving it a good try. But if you already do well with C channel and don't have extra cash to burn, I'd suggest stay with what works.
"For every great theory about design, there is a better and contradictory theory about design. And don't let the irony of that escape you."
Unread 15-11-2011, 21:41
Chris is me's Avatar
AKA: Pinecone
I'd prefer to use Kitbot rail than 80/20 in most applications. 80/20 does have that linear guide stuff, though, which does work.
Unread 15-11-2011, 21:49
ttldomination's Avatar
Sunny
We've been using 8020 for years, and it's definitely easy.
Building is a snap. You just throw together what you need/want. This can be both a blessing and a curse.
But here are some tips:
(1) 8020 is easy, but it's no substitute for good design habits. Be sure to still CAD and prototype like you would regularly.
(2) 8020 is heavy, but the trade off between weight and ease of use is worth it to some teams.
(3) It's a pain in the butt to drill holes in 8020, especially ones that are off the longitudinal axis.
(4) Don't be afraid to go out of the 8020 product line for various solutions. One particular case being linear motion. Find a solution you like, and then interface it into 8020.
As far as ordering is concerned, really try and order what you need. Obviously, you'll need long bars. I think our teams order it in tens of feet at a time. Other things are screws, drop in, slide ins, angle gussets, box gussets, flat gussets.
Don't be afraid to go looking into the 8020 catalog. They have some neat solutions in there, and over the years, you're sure to develop a nice storage room full of parts. But keep suggestion (4) in mind.
For the past 2 years, I've been trying to convince my team to move out of 8020 because of its weight and because how lazy it has made our team. But it's just so darn easy.
- Sunny G.
1648: 2013-2014
5283: 2015
Unread 15-11-2011, 21:59
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
80/20 is great stuff. It comes in different sizes. So you can use the smaller size for less weight. Also useful for prototyping especially if you do not have a welder. You can build bullet proof structures with it.
I would suggest getting in contact with your local distributor and seeing if they will give you a show & tell on how it works. They could also help with what you should order as well.
Unread 15-11-2011, 22:57
Dale's Avatar
Dale Dale is offline
Head Coach & Mentor
AKA: Dale Yocum
FRC #1540 (Flaming Chickens)
We, too, have been using 80/20 for years. We have moved away from it for our competition robots preferring 80/20's other product Quickframe because of it's lighter weight. 80/20 is fantastic for fairly simple robots like BunnyBots where the weight isn't as much of a problem or as a real-world alternative to CAD. Our students can throw a robot together in 80/20 very quickly to try out different ideas before committing to the more labor intensive Quickframe.
I'd say a Quickframe robot takes about three times longer to build than an 80/20 one.
Unread 16-11-2011, 06:24
jwfoss jwfoss is offline
Chasing Elegant Simplicity
AKA: Justin Foss
As someone who previously tried to avoid 80/20 (T-slot style) at all costs, being on a new team with limited resources meant trying to use more COTS items. To be honest, for the amount of time it took us to assemble our lift (frc2168) this year I couldn't be happier. We even ended up using the 80/20 and associated linear slides for our minibot deployment. As a side note, spray lithium made the lift operature much better than it did "dry".
My Suggestions:
For your chassis - Stick with kitframe. Its free, and great for what it does. Built correctly a kitframe will out perform 80%+ of other robots
For superstrutures - For COTS linear motion its hard to beat, but for most other things it turns out to be really heavy (0.5lbs/foot for the 1"x1"). Look into using square stock and gussets or the 80/20 quickframe.
Note that other companies make comparable products to 80/20 such as Bosch extrusion, However 80/20 seems to have a larger selection of accessories.
Unread 16-11-2011, 06:51
Ninja_Bait's Avatar
Ninja_Bait Ninja_Bait is offline
Former Prez of Making Things Go
AKA: Jake Potter
FRC #0694 (StuyPulse)
Ninja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond repute
It's also good for prototyping things that need to be adjustable, when you want to be able to experiment a little with dimensions.
However, it's designed to be adjustable. Sometimes things will start to slip or get knocked out of position. Try to avoid that, either by drilling holes or switching to extrusion or combining 80-20 with other systems that are fixed in place.
You can't fix something that isn't broken... but you can always break things that aren't fixed!
Unread 16-11-2011, 09:40
EOC's Avatar
EOC EOC is offline
AKA: Eric Curry
None #1208 (Metool Brigade)
EOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant future
Team 1208 has used it for 8 years. We have no machine shop and find it easy to work with. I gave a short talk on it at a recent FRC training camp. The hand out is attached.
Unread 16-11-2011, 09:44
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (EarthQuakers)
If you can find a local reseller with an agent who is willing to come spend a day with your team to optimize exactly what 8020 products you need, that is a day very well spent.
Hi!
Unread 16-11-2011, 09:59
gblake's Avatar
gblake gblake is offline
6th Gear Developer; Mentor
AKA: Blake Ross
no team (6th Gear)
Big Grin
Remove some of the weight and expense by making your own brackets to use a corners and other fastener locations. The 80/20 folks charge a ton for their simple, thick hunks of aluminum with a few holes drilled into them (the brackets).
Unread 16-11-2011, 11:10
AKA: Pinecone
Originally Posted by gblake View Post
Big Grin
This does help quite a bit, especially if you take advantage of the end tap on each piece of extrusion, but it's still going to be heavier.
Unread 16-11-2011, 11:29
jspatz1's Avatar
jspatz1 jspatz1 is offline
AKA: Jeff
FRC #1986 (Team Titanium)
jspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond repute
Send a message via AIM to jspatz1
The decision to use 80/20 depends a great deal on what fabrication resources you have. If you do not have access to the tools and shop resources to fabricate a more custom design from raw mateials, then it can be a great shortcut for some teams to achieve what they could not do otherwise. It is definitely NOT the most weight efficient approach, and is very expensive. All things being equal, for a team that has the means to fabricate whatever they want, it is not the most efficient or graceful method. It was designed to save time and labor in industrial machines and frameworks where weight was not a consideration. We do not use it because we are blessed with good fabrication capabilties, but for a team working from a garage with a hand drill, it can be a lifesaver.
Unread 16-11-2011, 11:36
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
We used 80/20 on our elevator in 2008. It worked well for what it was and wasn't too hard to assemble. All in all, 80/20 isn't bad if you don't have access to better machining resources but it's definitely not the best option.
^ Thanks, I needed a laugh. (It is really heavy.)
-Dustin Benedict
Unread 16-11-2011, 17:05
Tetraman's Avatar
FIRST on my mind
AKA: Evan Raitt
174 had an 80/20 elevator in 2005. Slipping the 80/20 bars between each other to create a "track" is a very cleaver way of using it, and worked out really well for that design.
You're welcome.
